Question about Siemens Washing Machines
Too much load, door will not open
Brand: varioperfect IQ300
Hi I ve an E11 flashing on my seimens iq300 washing machine it's brand new.. not used... I tried to use it it showed me this error. Please help
Contact the vendor from whom you purchased the machine. If it's brand new, they should replace it if it is defective.
Jan 25, 2017 | Washing Machines
The mashine doesn want to go on 1200rpm spin. It just spin at slowly. Model: Series 6 Varioperfect
Mine does this if the load is unbalanced, usually when it's got heavy items in it like bath towels, mats etc. I have to stop it, open the door, rearrange the items and start the spin again.
Sep 07, 2016 | Bosch Washing Machines
How do unlock the washing machine IQ300
Do not open the washer door by force while it is operating (high-temperature washing, drying, or spinning). Within 5 minutes as you start a wash, it is possible to add/remove laundry items. Simply do the following: Step 1: Press the Start/Pause button to unlock the door
Mar 25, 2016 | Washing Machines
A bosch varioperfect error code E29
E29 indicates a fill error. If the door is locking then check water feed. Make sure water is on and hose isn't kinked.
Jul 22, 2014 | Bosch Washing Machines
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
How do you remove the unlock on Exxcel 7 VarioPerfect washing machine?
Aug 13, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
