Question about andywjm2012 Portable Cryolipolysis Machine
Cryolipolysis machine WONT POWER ON
MY cryolipolysis machine STOPPED WORKING IT WILL NOT POWER ON AT ALL
Why my cryolipolysis head doesn't cool to the max
possibly broken check with the manufacturer . this not being anything automotive
Cryolipolysis - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Cryolipolysis
WikipediaCryolipolysis is a medical treatment used to destroy fat cells. Its principle relies on controlled cooling to near 4 Celsius for the non-invasive localized reduction of ...‎Method of action and animal
Mar 30, 2016 | Cars & Trucks
Does anyone know anything about it? is it safe? does it work?
look at the history of slimming of machines that have come on the market and make an intelligent decision
machines that sweated of the fat,shook the fat,rolled the fat, exercised the fat ( all called slimming machines) and now freezing the fat -- Yes --not worked to achieve slimming but the wallet got lighter
Have you not heard of hypothermia and frost bite and the fact that the body burns calories when cold to keep warm so you eat more
the machine will not be cheap
find forums on the product , talk with your doctor, dietitian and be aware that if you want to get slim, the procedure is to watch what and when it goes into your mouth, regular exercise ( not overdoing it) and a positive attitude is cheaper than any machine
Feb 10, 2016 | SainSonic Desktop Cryolipolysis...
Dishwashers wont stop.
By unplugging the machine, and temporarily stopping the drain from operating, you have diagnosed that the issue is electrical and not mechanical. If it were a mechanical issue (something stuck in the drain, thus keeping it open) it would continue to do so, even when the power is disconnected. It sounds as though you may have an issue with your timer, which tells it when to advance to each cycle. It depends on your make/model of machine. I've worked on some machines that have a cam style, and if the notches are damaged, it will not advance properly.
Mar 08, 2014 | Electrolux Dishwashers
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Machine stopped, no light on panel with power on, wont start
This sounds like it is an intuitive ECO model? Make sure the pump is correctly plugged in as it is a vital part of the electrical circuit and the machine will not power on otherwise. it's quite easy to disturb the wires when working with the recirc valve.
Mar 05, 2012 | Fisher and Paykel Washing Machines
Machine stopped running, its getting power but wont run.
Are you sewing or embroidering? If you are embroidering, the machine automatically stops and shows scissors in the window, for you clip the jumpstitch. Then just push the "Run/Stop" button.
Dec 13, 2008 | Husqvarna Rose
Washing machine.Fisher and Paykell Kelvinator
check the lid switch under the lower board they rust and the fault is normally not starting,or the display board can rust inside near the start/pause button if so try and unsolder a button you dont use and replace the start button.
Mar 03, 2008 | Washing Machines
andywjm2012 Portable Cryolipolysis Machine Logo
398 people viewed this question
Top andywjm2012 Sport & Outdoor - Others Experts
Are you an andywjm2012 Sport and Outdoor - Other Expert? Answer questions, earn points and help others
