Question about Samsung WF328AAW Front Load Washer
Error code ds
When you press start has code de
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
Error code 52100
Hi there! There are a couple options you could try to solve this problem!
To solve this error :
I would first check Nintendo's special notes router infomation page located here.
  • If you can't locate your router on Nintendo's special notes router information page, log into your router and change the basic rate to 1-2 and the transmission rate to 2. Try to connect again.
  • You can try to manually assign an IP address to the Nintendo DS as another device may be sharing the same IP address of the Nintendo DS.
  • To manually assign an IP address to the Nintendo DS, on a PC click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter. The IP address for the Nintendo DS must be 10 digits higher than your PC, for example 192.168.1.200 becomes 192.168.1.210. Also make sure that the correct DNS is the entered under the DS manual settings.
Hopefully one of these options is your answer and you can easily fix your problem! Good luck! If you need any further assistance I would suggest calling Nintendo at 1-800-255-3700.
Jun 03, 2011 | Nintendo DS Lite
Getting Error code : 052000-1
Error Code: 052000 Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps:
The first thing you'll need to do is find out what IP address range you should be using. To do this:
  1. Click the "Start" button in the lower left-hand corner of your computer.
  2. Next, you will need to access the command prompt. To do this:
    • Windows XP users click "Run."
    • Windows Vista users click inside the search bar.
  3. Type "cmd" into the box and press Enter.
  4. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed.
The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The DS and PC must have different IP addresses.
Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Nintendo DS and for your PC.
  1. Click here to go to our Wireless Router Configuration page.
  2. Use the drop-down box on the left to select, if available, your router manufacturer.
  3. Click on your router's model number, if available.
  4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection.
You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this on your Nintendo DS or Nintendo DS Lite, please click here.
Check Nintendo's router info for special notes, if available, for your router.
If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below:
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Aug 16, 2010 | Nintendo DS Lite Console
System date error! Please check NDS system date.
Goto system date settings on the DS and change it to 13/04/2010
Apr 14, 2010 | Nintendo DS Lite Console
Can't connect to wifi error code 052000-1 how do I correct this
Error Code: 052000-1 Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps:
Feb 03, 2010 | Nintendo DSi Black Console
Ben in het bezit van een Sharp AR-335 machine. Geeft nu de CODE: U2-00 Hoe moet ik handelen om de machine weer normaal te laten functioneren?
Hello sir; You may reset this error code; the procedure as follow;
press"program" "interupt" "clear" "interupt",(interrupt also call pause key),then enter16 press start and clear.
Jan 06, 2010 | Sharp Office Equipment & Supplies
I'm trying to download Action Replay codes to the DS but I get a list of Error! messages on the DS.
hold A + B and than press START and SELECT while holding A+B, after while holding all together, it will like be white screen...than let go after 10 seconds. After that you go to action replay. Type ur game name and there.Its fixed
Aug 05, 2009 | Nintendo DS Lite Console
DS stuck in foreign language
go to a language converter on the internet and enter line by line into a language converter and de code the gibberish to english little by little it will start to make sense
Feb 16, 2009 | Nintendo DS Console
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
Samsung WF328AAW Front Load Washer Logo
16 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
