Question about Cricut Expression Cutting Machine
Cutter my cricut expression 2 is dragging across before it starts cutting
One or more of your cut images are not positioned entirely on the mat, They will be skipped
Just follow the steps given at this link, and your cutter should begin to cut again. I just tried it and my cutter is back cutting. Cricut Craft Room Troubleshooting Cricut Help Center
Aug 01, 2016 | Provo Craft Cricut Mini Electronic Cutting...
I have the original Cricut and have never had a problem. Now it won't cut. Nothing happens when I hit the Cut button. Is there a way to fix it?
Hi you could try's phoning cricut. It's free to the states. The number is on the website. You may have to wait on hold for a while but they will answer and you will definitely get an answer.
Feb 28, 2015 | Provo Craft Cricut Expression Personal...
How can I get a new Encoder board V2Encoder for a Cricut Expression?
You may be able to get a replacement circuit board from the source where you purchased your Cricut Expression. More likely, It will require an inquiry to Provo Craft to determine availability and source.
Feb 02, 2015 | Provo Craft Cricut Expression Personal...
Cricut expression 2
Cricket is hung up on the first small cut and keeps repeating that same cut over and over
Aug 09, 2012 | Toys
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
The cricut blade holder doesn´t go up or down.
My housing was not going up or down. Every time i wanted to make a cut it dragged and cut shapes in half. So when I took it apart I pushed it up and down myself and noticed that it was very difficult. So where you see the coils, I lightly sprayed WD40 (my cricut is out of warranty, I would not advise to take apart if you are still under a warranty). I lightly sprayed until it was easy to move up and down. When your done be sure to wipe any access WD40 that dripped to the bottom. This fixed mine and thank goodness because I was close to pulling out my hair! Hope this helps someone else!
Jul 26, 2010 | Cricut Expression Cutting Machine
Cricut personal blade appears to be dragging
Have you checked to make sure the blade is inserted all the way??
May 22, 2009 | Provo Craft Cricut Disney Font Cartridge
Cricut Expression Cutting Machine Logo
47 people viewed this question
Top Cricut Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
