Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
Pressure transducer 39853791
I would like to know the spec. of the pressure transducer. The pressure range should be 0 to 225psig How about the output signal? 0 to 56.25mv How about the mounting port size and thread?
I have Kenmore washing machine showing F1
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
Jul 25, 2017 | Kenmore Washing Machines
Error code 66
66. (01000010) - Pressure Transducer Out of Range Error
The Motor Controller has received signals from the Pressure Transducer outside normal values.
Primary Source - Motor Controller
Action - Replace Motor Controller
Feb 11, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Error code F1
What is the model number?
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. This can be caused by the pressure transducer air hose tubing being pinched or crimped. It can also be caused by a failed pressure transducer on the machine control board.
Nov 14, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Error code 1f
Nov 05, 2012 | Kenmore Washing Machines
F1 error code
Oct 15, 2012 | Whirlpool Washing Machines
When I start the machine on Normal setting, it stops and flashes "F1" and beeps. what does this mean?
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. The control board needs to be replaced.
Hope this helps.
Shane
Mar 08, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have been getting a F1 error for months now and have restart my cycle 3 to 5 times a wash. I heard this is a common problem with this model is it a recall? what do I do
Thank you for your question.
The first image below shows the method for accessing the pressure transducer tube that runs from the bottom of the washer tub to the machine control. I recommend checking this air hose for pinches, twists or crimps.NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced.
Jan 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Keep getting F1 code.
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it. I recommend checking this air hose for pinches, twists or crimps. If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced.
Jan 21, 2011 | Kenmore Washing Machines
Kenmore elite, oasis, model # 110.2703, at exactly 19 min left, at the starting of the rinse cycle it flashes the F1 code, i push stop then start untill it stays on, usually takes about 4-5 trys
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below.
Jan 09, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis washer, top load that flashes F1 at the rinse cycle, what part do i need to fix this???
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below. The part number for the machine control board is W10189966.
Image 1
Image 2
Jan 09, 2011 | Kenmore Washing Machines
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
62 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
