Question about Sansui HDLCD-2600 26 in. LCD Television
Sansui tv not starting showing blank screen
Sansui tv
My sansui hdlcd1955e i can turn it on but it goes blank it still shows the green light on but it wont let u do anything i try to chagne the chanle but it wont let u
Only a green screen is a bad symptom. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen shots to defective LCD panels are given. You can compare it to that of your TVs'.
May 11, 2014 | Sansui HDLCD1908 19 in. LCD TV
Sansui tv 32"tv switches off after a while and sometimes only audio is heard but only a blank black screen is seen
Check and replace its back-light inverter board. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Electro help
Jan 13, 2014 | Televison & Video
Sansui 24 in. Flat screen and hooking up a Xbox
Please open the menu go to color systems and change the setting which brings the colors.
Dec 30, 2013 | Sansui Televison & Video
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
Dear Sir,will you be pls to get me the circuit diagram for 34" color tv SVT3"4 ...2003 MODEL pls help
Hello wilson_deniz,
Welcome, and thank you for using FixYa!
The maunals you seek can be found at the link I have included below. But you will have to locate your Model Number on the back of the TV. The manuals also cose $4.99 each.
Sansui Manual
http://www.sansui.owner-manuals.com/SANSUI-manuals-6-20a.html
Small price to pay if it helps you fix the TV.
Have a great day!
Sep 11, 2011 | Sansui 32" TV
On swiching on my sansui 21 inch tv it is producing a sound gradually increasing in intensity and the screen is blank(black). any action through remote control is not being executed. wat is the problem
You are losing power in the vertical section. This will start with bad capacitors. Pay attention to capacitor (locations) C515, 25 volt@10MF, C423,50volts@4.7Mf, C407,35volts@ 100Mf, and C406,50 volts @1Mf.Please pay attention to any 50 volt 1 MF caps not mentioned. These are located near the audio IC, they are very small as the one mentioned earlier.Also, resolder the vertical IC, as there are rings around the pins at the bottom of the board. Start with these procedures and the picture will return and then sound will be stable. Be very careful when you you remove the capacitors. The traces are very small and delicate and you can destroy the TV. Once again....please very careful when you replace these components. Thanks for asking and show a few hands of support.
Dec 16, 2010 | Sansui DTV2700 27" TV
I have a Sansui HDLCDVD260, 26in Television that I can't get the monitor to work on. TV works fine, DVD player works fine but when I hook up the SVGA cable to use as a computer monitor it just shows a...
After you have set the refresh rate to 60hz and the display mode to the recomended setting, shut down the computer. Turn on the tv and select the pc input on the tv. Connect the computer to the tv and then power up the computer.
Dec 25, 2008 | Sansui HDLCDVD260 26 in. LCD Television
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
My Sansui recorder records blank when I use the timer!
first of all make sure the time and date is set correctly on your recorder (options or set-up usually) second make sure an aerial input is going to your recorder (not just to your tv (the recorder is in the loop with aerial lead to it then from it to tv)) third make sure the on-board tuners are tuned to the correct tv channels (recorder is just a tv without a screen and has its own channels that need to be tuned in)
Jul 13, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui HDLCD-2600 26 in. LCD Television Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
