Question about KitchenAid Coffee Makers & Espresso Machines
Coffee machine gage that doesent move
The gage is stays low
  • KitchenAid Master
  • 1,316 Answers
If the model is KES100 and coffee and steam are both at normal temperature then the problem is one of the following
1) The needle has come loose on the shaft. Solution; turn machine on and press needle back onto shaft in the usual position for full heat when the machine is on full heat.
2) The gas/liquid has escaped from the copper tubing to the gauge. Solution; fit a new gauge assembly.
Posted on Mar 26, 2014
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
My Senseo coffee machine is making a grinding noise, Is this a sign my machine is dieing?
There are no moving parts except for the pump. There might be some contamination in the pump (lime?). As this is a low cost machine, replacing the pump is not worth the cost.
Feb 19, 2015 | Philips Senseo HD-7810 Coffee Maker
Fix water level censor tassimo
Check to e if the magnet in the reservoir is moving up & down if not then try to place a magent on the back of the machine
Aug 26, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Steamer Button doesn't work
hi ROC,
the steamer works? can you do foam with milk?
perhaps its the thermostat to regule the heat.
sorry, my english level is low, im french.
Apr 15, 2014 | Gaggia GRAN Espresso Machine Cappuccino...
I have a rancillio epoca dual head espresso machine, there are two gages on the front of the machine, steam is coming out of the top gage
You will need to get that manometer changed. Get a hold of a rancilio dealer and tell them you need a steam manometer.
Sep 29, 2011 | Rancilio Silvia Espresso Machine
Took tray and grounds tray out to clean and it won't go back in - it is jamming. Have cleaned inside but still stuck. Tried pulling infuser out but this is stuck as well. Appears that central unit has...
I had this problem last night. The infuser was stuck down too low and the tray wouldn't slide in. I got the solution from FIXYA, and it worked for me.
First make sure machine is off at power, then put just the coffee grounds collector and not the whole tray back into place, gently close the door, and then turn the machine back on. At first I couldn't close the door, but I fgured that the grounds collector was a bit too low, so just put something in there to hold it up while I shut the door. Turn the machine back on at power and HEY PRESTO, it all started up again, and then the infuser moved back into correct position.
Make sure you have a cup handy just incase water starts to rinse out.
Hope this helps
Tania
Sep 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
WEAK espresso from Saeco Vienna!
Well, when you set it that low it allows the water to pass very quickly and if the water passes very quickly there may not be sufficient time to absorb the coffee; hence weak coffee. The setting should be reset to the middle, at 10, and tried again. Then, if you want to change it move it only one or two numbers for enough cups to see if there is any change before you move it a large number. Going higher or lower makes it pass more or less quickly with results accordingly.
You may also have the dose set too low and you may want to set it higher increasing the amount of coffee in each dose.
Then again, since it was used, you don't know if the machine was taken apart by someone who reinstalled the machine with the dials you are using out of whack with where they should be set.
George W Conrad.
Apr 02, 2009 | Saeco Vienna Espresso Machine
No power after water spill
Pre heat your oven to 125 degrees or as low as it will go, when it reaches that temp. turn the oven off and put in your coffee maker, let it stay until the oven cools down and repeat three or four times, that should  dry out the electrical components.  Good luck.
Jan 28, 2009 | Saeco Vienna De Luxe Espresso Machine
My saeco vienna machine grinder is not working at all,Any sugestions
Looks like you would need to have your machine serviced.
www.Saeco-usa.com for a Service Center list or
www.CeriniCoffee.com for Service near New York.
Nov 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
Top KitchenAid Coffee Makers & Espresso Machines Experts
Ismael Rodriguez...
Sal De
Craig Butler
Craig Butler
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
