Question about Juicers
Sanyo juicer SJ-BJ12
Button on/off can't work
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
I have a Homemaker HY5028. It's hard to clean it without taking the sieve out. Is it possible to take the sieve out without damaging it?
You need to use a knife or something to push down the small black release button then it will lift straight off. I got my daughter to push down the button as i lifted.
Aug 23, 2011 | Juicers
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
Not sure how to assemble juiceman jr juicer,
Model #JM01C K: The motor works. The black start button works. The on-off Switch does not engage with the start button when moved up and down. Am I missing a part?
Dale
dale@webr4m.com
Jan 03, 2011 | Salton Jr. JM1 Juicer
Motor failure
First, turn off the power at the circuit breaker and look for a small reset button. There should be one. If not, leave the juicer on off - and turn the circuit brkr. back on, and try again. If this still doesn't work. Check and see if you're plugged into a GFI receptacle, which has a little reset button on it. In fact, you can check this first. Good Luck to you! Feel free to contact me again if this doesn't work for you. - Jim
Mar 29, 2010 | Breville BJE200XL 700 Watts Juicer
Jack lalane power juicer pro stopped working after 3 uses. seems to be no power going to it.
my jack la laine power juicer stopped and won't start again...i have used it less than a dozen times over the past 8 months. is there a restart button? anybody have this problem or do I have to send it in and pay $30.00 just for shipping and handling on that so-called 'warranty'?
Jan 19, 2010 | Jack Lalanne Power Juicer 250 Watts
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Juicerator motor died
TRY PUSHING RED RESET BUTTON ON BOTTOM OF JUICER.
Apr 20, 2009 | Acme 5001 Supreme Juicerator Juice...
The pulp collection receptacle has a tiny clear plastic button on the bottom. If this has broken off (it happens often) the machine won't turn on. The button must be present to depress the safety switch at the bottom of the machine. If everything else is properly assembled and the machine won't turn on, this is probably the cause. Check the bottom of the pulp collection receptacle to see if the button has broken off. (picture #2) If so, replace it with a piece of pasta or a tiny piece of wood. Sounds silly, but it works. The safety switch at the bottom of the machine must be depressed before the machine will run.
Nov 04, 2008 | Jack Lalanne Power Juicer 250 Watts
The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Oct 06, 2007 | Acme 6001 Juice Extractor
Juicers Logo
29 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
