Question about Vehicle Parts & Accessories
2001 ford taurus problems
Air not coming out of A/c outlets. coming out of defrost
    Sergeant:
  • 243 Answers
THE control for the door that switches where the air comes out is most likely vacum operated. try with the engine running to switch the air to the ac outlets, if nothing happens, rev the engine up a little then quickly let off the accelerator peddle. if the valve switches, you have a vacum problem and you would need to pull the switch and repace any hose that is cracked or really lose.
Posted on Jan 27, 2015
2001 ford taurus air bag code 14 fix it so the light will go off ?
Well you can disconnect positive battery terminal.Disconnect for ten minutes..then reconnect lite should be off ..but if problem remains it may come back on soon..good luck
Nov 16, 2016 | 2001 Ford Taurus
2003 ford taurus blows cold air out the defrost
Sounds like your hot/cold door is stuck on cold. Is the heat not hot either? If so that could be it. Perhaps your heater core. Good luck.
Jun 08, 2014 | 2001 Ford Taurus
2001 Ford Taurus No Heat I am having trouble with
possibly the bled door is stuck open so only the cold air from a/c works when on defrost vs closing to allow heat to cycle through the system as defrost runs through the a/c system
Sep 18, 2013 | 2001 Ford Taurus
I just bought a 2001 Ford taurus. The heater works, but will only blow air through the defroster and floor outlets. It will not blow air through the vents on the dash panel.
it sounds like it could be a problem with the vacuum motor it could also be a vacuum line or the switch. I would check the vacuum motor first when you check the vacuum motor you should also be able to see if there is vacuum in the line. if there is no vacuum in the line I would check the switch next.
May 12, 2011 | 2001 Ford Taurus
2202 ford taurus heat and defroster problems.Cold air comes out only
More than likely the thermostat is stuck open. Should be a rather cheap part and autozone can print you instructions or you can look on their site for direction.
Nov 21, 2009 | 2002 Ford Taurus
Air wont come out the front vents only the defrost
Check for a vacuum leak. Trace from engine to a/c control head. Usually the leak is under the hood.
Nov 08, 2009 | 2001 Ford Taurus
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
