Technical spec of the freezer compressor on a Defy F640F
Compressor size - freezer
  • 183 Answers
SOURCE: freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Posted on Aug 21, 2007
docjohn174
  • 943 Answers
SOURCE: fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
Posted on Oct 30, 2008
  • 19 Answers
SOURCE: head bolt torque spec for this compressor
220-300 in lbs work from center out
Posted on Feb 01, 2009
bobicehouse
  • 1524 Answers
SOURCE: Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
Posted on May 30, 2009
SOURCE: my freezers compressor is getting very hot and the
Fridgidaire Upright Freezer appears that the compressor is getting hot enough to burn ( serious discoloration) the linoleum below the freezer.
The compressor is hot to the touch.
Freezer is working just fine.
What to do?
Posted on Aug 29, 2010
DEFY F640 Fridge/Freezer side by side. The freezer made clicking sound, and green light flicker for a while then stops. Now it is not freezing anymore.
Hallo
It could be the theromstat, clicksen or the compressor.
But I think its the clicksen it is faulty and can't handle the amp stress test I hope for your sake other wise I believe its the compressor.
Regards
May 26, 2016 | Refrigerators
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
I need to know the correct torque specs for the 4 bolts that hold the a/c compressor on my 2003 Suzuki Aerio. In order to replace the water pump it was necessary to remove the compressor. The book supplied...
The ac compressor bracket bolts are to be torqued to 40 ft lbs, as far as the compressor itself you can just hand tighten bolts, there is no specs for compressor bolts just bracket, the bolts are just snug.
Aug 28, 2012 | Suzuki Aerio SX Cars & Trucks
My upright freezer has stopped working. compressor cuts in every now and then, but cuts straight out after running for about 5 seconds.
your compressor is busted due to low chARGE OF OIL in the compressor or meybe the internal overload of the compressor collaps you must replace your compressor with the same s/n num..and size...
Aug 11, 2010 | Freezers
Out kenmore side by size freezer 10 years old with never any problems, notice the freezer isn't very cold and stuff is softening. Help!
First, check to make certain the compressor (underneath the refrigerator) is running. Second, make sure the compressor fan (near the compressor) is running. Third, make sure the evaporator fan (inside the freezer, likely behind an access panel) is running.
In checking on the compressor and compressor fan, look at the refrigerant coils. If they are dirty, they need to be cleaned.
Oct 18, 2009 | Refrigerators
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
