Question about Samsung HLN467W 46" Rear Projection HDTV
Dlp light doesn't lite up
Replaced light
I replaced 2 bad leds , now have no back lite at all. fails back lite flashlight test. I have sound (static noise) what could be the problem? thank you Garry
After you replaced 2 bad leds the back lights stopped working?Possible that when you did the soldering you may have inadvertently shorted something out? Was working before you touched it so ...............Th is a puzzlement.
Meanwhile is set connected to signal source? If so you should at least have audio. If not that alone is a main board issue. You might want to check this site for further info and parts
. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 19, 2017 | Televison & Video
Samsung DLP HLS4266W
Check the fittings of the color wheel. Refer this site for more details.
May 17, 2013 | Televison & Video
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
EP1691 black spot, no bulb
How big is the spot? is it always in the same spot? it seems that you have dust in front of the LCD.
Tony
Feb 19, 2013 | Da-Lite Optoma Ep1691 Wxga Dlp Multimedia...
Re sagem dlp 50 d4 tv
Hi,You get the lamp indicator when ballast(board that powers the lamp) is not able to light the bulb or bulb i not responding.Make sure everything is properly closed and have someone check if ballast is providing right voltage to the lamp.
Apr 07, 2010 | Televison & Video
Speckles in dlp tv screen samsung 50" dlp
No they couldn't have replaced everything or did they Replace Light Engine? Because that is what is Bad on your TV if under warranty get it Fixed Now Light Engine is very COSTLY !!!!!!!!
Sep 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Light blink 3 times
If this is a Sony dlp then check the lamp door for warp, if this is not a Sony need model and brand. Or if it is a Sony but not a DLP then still need model.
Sep 13, 2009 | Sony KDF-50E2000 50" HDTV
Samsung HLN467W 46" Rear Projection HDTV Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
