Question about Fisher and Paykel Dishwashers
I have a fisher & paykel DW60 dishwasher. Worked fine for the last 3 years. Tried to turn it on last night, it started to run and then it stopped with water still in the dishwasher. Turned it o
Dishwasher selects the function but won't start
  • Fisher and P... Master
  • 3,247 Answers
See if there is any difference if you turn the mains power off and back on.
please check if any fault conditions in the troubleshooting section of manual are applying.
http://manuals.appliancesonline.com.au/dw60cdx2/dw60cdx2_user_guide.pdf
Posted on Apr 11, 2014
SOURCE: Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Posted on Mar 15, 2008
stephanos18
  • 144 Answers
SOURCE: Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Posted on Mar 27, 2009
whytfang
  • 170 Answers
SOURCE: GE Nautilus dishwasher wont run
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
SOURCE: Dishwasher beeps 3 times and won't start
I finally solved this problem by doing the following:
I removed the front plate, this can be done by removing the two round plugs one on each side of the lower front of the washer just above the rack. once you do this the front comes off, then you remove the ground wire. From the front upper right there is a photo sensor in two plastic tube, make sure they are in correctly and not slipped out of position.
My washer, it appears the plastic casing that is holding the circuit board and the sensor broke off on one end, I simply taped it to the main body by using electrical tape and made sure it was secure.
I put everything back and now my washer doesn't stop anymore.
Posted on May 31, 2009
SOURCE: Asko dishwasher won't start, just hums and gets hot
Get this every few months - don't know the problem but we disconnect from unit and tilt the dishwasher and loads of stinky water spills out - from where I don't know. Then just **** all the water out of the drain bit with a chicken baster - primative but has worked every time so far. Keep trying to get water out until doesn't hum when switched on.
Posted on Feb 15, 2010
Fisher & Paykel DW60 dishwasher will not start. All LED's stay on and program cannot be selected.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 08, 2015 | Fisher and Paykel Dishwashers
Tip
Determining the Age of Your Fisher & Paykel Appliance
This advice applies to Fisher and Paykel appliances. Determining the manufactured date of most appliances is accomplished by looking at the SERIAL NUMBER. On Fisher and Paykel appliances this is determined by the by the 1st two letters of the serial number.
The 1st letter represents the YEAR of manufacture.
The 2nd letter represents the MONTH of manufacture.
Example: DHL121796
LETTER YEAR
C - 1
U - 2
M - 3
B - 4
E - 5
R - 6
L - 7
A - 8
N - 9
D - 0
LETTER MONTH
F - 1
I - 2
S - 3
H - 4
E - 5
R - 6
P - 7
A - 8
Y - 9
K - 10
U - 11
L - 12
In this example the appliance was manufactured in April of 2000.
on Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
My Fisher and Paykel dishdrawer has worked fine up until a week ago when it started being temperamental. It stops during the wash cycle anything up to 5 times claiming that it has no water. I push start...
I don't know if this will help. I had to work on Fisher & Paykel two draw dishwasher. The one problem was one draw would work but the other wouldn't. There is one board for each draw and one board in the base. The board in the base seem to be the power supply for the rest of the machine. I don't remember the model number and it has been years ago. Getting to the boards was not easy.
I did the swap the two draw boards and the problem didn't move. So whatever the problem was it was in the draw. I found Fisher & Paykel had design the heating element as a resistor to drop the 110 VAC down to a voltage the logic/controller board can use turn to Dc voltage to run board. The problem I found was the heating element had opened. There was no power to run the board. Later there was also a cable problem the confounded the repairman. He had to replace the draw harness.
My really big problem is the heating was on the ground side of the logic/controller board. The logic/controller board was on the 110 VAC side. So that if the heating element opened the logic/controller board would be floating up to 110 VAC. So any meter measurement on the board show 110 VAC. Even touching any part of the board and any part of washer you can get zapped. So be careful. It should the other way around so the board is at the ground side and heating element on the high side. If the heat element opened there would be no power to the board would be at ground level and no shock problem.
Apr 26, 2017 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishwasher DW60CSX1
I have a dishwasher - "Soft Touch" which seems to be stuck on F1. This occured in the middle of the night and although turning off at wall cannot get it off this setting
Jul 11, 2009 | Fisher Dishwashers
No power
top drawer turns on runs aprox 3 min then starts to beep and we have to turn it offthe clock pops up and and stays at 2;00
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
Jun 21, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Fisher&Paykel DW60 drain pump is blocked.
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Dishwashers Logo
344 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
