Question about Dell Ax510pa Soundbar Lcd Monitor Speakers Dw117 C730c
Ax510pa soundbar wont play
Just had to have a new hard drive installed on my dell inspirion and now I can not play the sound bar
SOURCE: Install new hard drive
If all that you are doing is replacing the hard-drive then you only need to do the following as the Dell cases are a screwless design and only require you to:
  • pop the case open,
  • disconnect the drive and power cables, (noting these for reassembly later)
  • push the green drive rail tabs inward toward the drive, and
  • remove the drive from the case.
Next you'll need to replace the hard drive.
Tools needed:
  • Philips head screwdriver, or
  • Nut driver.
Procedure:
  • Take the old hard drive to a flat space, ideally a workbench and unscrew the four mounting screws from the drive rails.
  • Take your new hard drive out of its Anti-Static bag and begin to put the drive rails back on the new drive.
  • If this is the only drive in the PC I suggest you set the drive to being the Master drive on the IDE bus. If you do not know what this means google the drive model (on the label on the hard-drive) and you'll find details of how to set up the drive to be the master on the IDE bus.
When the above procedure is complete you'll need to re-insert the drive back into computer case. That is simply reversing the procedure you used to take it out of the case.
Finally you'll need to reboot the computer and go into the BIOS to ensure that the drive is being seen and is of the correct size.
Lastly you'll need to pop in the OS CD-ROM and rebuild the system.
Note that on some of the early GX150's there was a problem with the firmware of the CD-ROM that allowed you to load the OS, reboot and then the installation would hang as the OS could not read the hardware due to an incompatibility. This can be solved by simply replacing the GX150 CD-ROM with another CD-ROM during the build and then putting the old CD-ROM back in place after the final reboot of the PC before you log on for the first time.
Hope this is of some help from a newby solution provider.
Sincerely
Andrew Martin
Posted on May 21, 2008
SOURCE: Problem with Dell AX510 Soundbar
in order for your sound to work you have to disable the on board sound in the bios . unless you already did the , then i would return it and get a different one.
Posted on Apr 20, 2009
ankurkorwa
  • 12 Answers
SOURCE: internal hard drive not found dell inspirion
Try re-booting the system in safe mode and go to my computer->manage->hard drive..try to refresh it from there.
Posted on Sep 05, 2009
SOURCE: No sound dell Inspiron 8200
If your touch pad doesn't work too, there is a connector under the keyboard that affects both the sound and touch pad. It may have come disconnected.
Posted on Oct 25, 2009
SOURCE: Dell Inspirion 1521 Laptop Microphone Wont Work
I have a Dell Inspirion 1521 same mic issue.....so it was corrected driver R167846
Title: Audio: SIGMATEL STAC 92XX C-Major HD Audio Driver
Version : A02
OEM name : SIGMATEL
OEM Version: 6.10.0.5609
Computers : Inspiron: 1420, 1520, 1521, 1720, 1721; Vostro Notebook: 1400, 1500, 1700; XPS: M1330, M1730
OSes : Windows Vista 32-bit Business,Windows Vista 32-bit Home Basic,Windows Vista 32-bit Home Premium,Windows Vista 32-bit Ultimate,Windows Vista 64-bit Business,Windows Vista 64-bit Home Basic,Windows Vista 64-bit Home Premium,Windows Vista 64-bit Ultimate
Languages : Brazilian Portuguese, Chinese-S, Chinese-T, English, French, German, Japanese, Korean, Spanish
Created : Wednesday, November 07, 2007
Posted on Feb 27, 2010
How do I replace sound bar on monitor?
Deb Powell,
Reverse the steps listed below. They are for connecting the sound bar.
1. Working from the rear of the monitor, attach the Soundbar aligning the two slots with the two tabs along the bottom rear of the monitor.
2. Slide the Soundbar to the left until it snaps into place.
3. Connect the Soundbar with the power brick.
4. Plug the power cables of the power brick into a nearby outlet.
5. Insert the lime-green mini stereo plug from the rear of the Soundbar into the computer's audio output jack.
NOTE: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only.
NOTICE: Do not use with any device other than Dell Soundbar.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2016 | Dell E197FP LCD Monitor
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
Dell laptop HD
This model laptop came with a 60Gb hard drive and it will work with a 40Gb hard drive.
If it was me I would install a 60 Gb hard drive not a smaller one.
Apr 30, 2013 | Dell Inspiron Computers & Internet
Advent Soundbar Model AONXT09 worked with Dell laptop on Vista. New Acer Laptop on Windows 7 does not plug and play the soundbar. Any ideas to resolve
1. Test to see if the problem is with the soundbar or with the computer by plugging the soundbar into the audio output of another device.
2. If there is no problem with the soundbar, then I would look at the driver, which you can download from the manufacturer's website. Before reinstalling, be sure to uninstall the current driver on your computer, then do a defrag of the harddrive, then install the new driver. Very often problems with drivers can be resolved simply by defragmenting the drive.
Mar 11, 2011 | Computers & Internet
Dell inspirion 1525 will not boot upon power up...only displays locked 9 light solid
This is a Hard Drive error. If your unit is under one year old, you can get the drive replaced by Dell.
The drive can be accessed outside the laptop to retrieve the data, but it may fail all together very soon.
If you have no data on it, just get a new Hard drive installed. Dell should be able to replace the drive and start the system restore for you.
Mar 28, 2010 | Dell Computers & Internet
Hard drive caddy stuck
Try giving it a lift and then try to remove it.
Feb 05, 2009 | Dell Inspiron 2200 Notebook
Dell Ax510pa Soundbar Lcd Monitor Speakers Dw117 C730c Logo
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
