Question about Janome Memory Craft 350E Embroidery Machine w/ FREE BONUS
Short of memory space , file cannot be saved, box appears and I can't do any further
I put my USB in and select my design and that box comes up, (short of memory space, the file cannot be saved, and I can't any further, I have to turn machine off to do anything else,
    New Friend:
  • 77 Answers
1) USB stick may have more on it than machine memory can handle. Try using a 512 or smaller stick and only have embroidery designs on the the stick. The machine has to read everything on the stick to determine which are designs and which are not.
Posted on Apr 23, 2014
My memory card is not format in pc
Put your drive into a USB port; right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
May 21, 2014 | SanDisk 2GB microSD Memory Card
Janome 350e embroidery machine will not open files from usb
Machine memory is FULL. delete a few designs from the machine, and then you should be able to load a new design from the USB Drive.
Jan 30, 2014 | Sewing Machines
Janome help
Your machine memory is full, delete a design or two from the machine's memory and you should be good to go with the new design.
Printer error 70
Brother DCP-165C inkjet All-in-One Printer Error Messages
Once you are familiar with the types of errors that can occur while you are using PhotoCapture Center, you can easily identify and troubleshoot any problems.brother-dcp-165c.jpg
Hub is Unusable.
This message will appear if a Hub or USB Flash memory drive with a Hub has been put into the USB direct interface.
Media Error
This message will appear if you put in a memory card that is either bad or not
formatted, or when there is a problem with the media drive. To clear this error, take out the memory card.
No File
This message will appear if you try to access a memory card or USB Flash memory drive in the drive (slot) that does not contain a .JPG file.
Out of Memory
This message will appear if you are working with images that are too large for the machine's memory.
This message will also appear when a memory card or USB Flash memory drive you are using does not have enough available space to scan the documents.
Media is Full.
This message will appear if you are trying to save more than 999 files in a memory card or USB Flash memory drive.
Unusable Device
This message will appear if a USB device or USB Flash memory drive that is not supported has been connected to the USB direct interface (For more information, visit us at http://solutions.brother.com.). This
message can also appear if you connect a broken device to the USB direct interface
Nov 03, 2010 | Brother DCP 165C Compact Color Inkjet...
I want to know what i need to do next after i have put my sd card into my computer, a green light comes on, and i want to know how to get my pictures to come up on my computer, so i can do any adjustments...
1. When you insert a memory card into your computer, it'll be detected automatically and an "AutoPlay" dialog box will ask you to what to do ?
2. Select "Open folder to view files" option from the list.
3. Now, you can easily view the files in the memory card by double-clicking them.
4. If the "AutoPlay" dialog box doesn't appear, goto Start >> My Computer. Here you can view the memory card as a "Removable Drive" with some name!
5. Double-click the memory card's icon to view the files inside it.
6. After your job is complete, you can remove the memory card by just clicking the USB device icon at the right side of Task Bar (Notification Area)!
7. On click, a single option pop-up will appear with "Safely Remove USB Mass Storage Device" message!
8. Just click on that pop-up. A "Safe To Remove" message box will appear.
9. Click on OK button, and manually remove your memory card!
please rate this advice if it helps...tc! :)
Jan 12, 2010 | Electronics - Others
How to store a letter from microsoft word 2003 on to usb memory stick?
insert your USB memory stick on your pc then open your "my document" locate the file you want to save then right click on that file then select "send to" another dialog box will appear and select the USB model your file will transfer automatically.
to check if you copied it successfully double click on my computer then double click on the USB model you can now see the content of the USB espacially the one you transfer
hope this help
Oct 19, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 2.0GB disk full - but it's not full!
1. Right click My Computer and select Manage.
2. Open the Device Manager and find your USB drive under the Disk Drives heading.
3. Right click the drive and select Properties.
4. Choose Policies tab and select the "Optimize for performance" option.
Click OK.
6. Open My Computer.
7. Select Format on the flash drive.
Hurrah there is NTFS option available now
8. Choose NTFS in the File System dropdown box.
9. Device Formatting is completed.
Important: To remove a device safely without data loss use a "safely remove hardware" procedure or Eject function from Windows Explorer.
Apr 04, 2009 | Electronics - Others
Formating memory
You need to format the usb stick in the machine itself, don't use a high memory one or one that has a partitioned area. 1 gigabyte or lower. You need to use the set icon on the machine and arrow through the pages to find the Format screen. Select the tab for USB device. Then click yes to the prompts, that installs the correct folder system. Now the software end,open easy design and select machine from the top toolbar, set machine type to 11000. Open a design and use the file drop down menu and select Save As, choose JEF in the file type bar, you will see a button below Save , Delete, called options, click on it, you'll find a list of machines, set it for the 11000. It is that selection that saves the design in the correct format. There are 2 jef formats, the old Jef for the previous machines and the enhanced Jef for the 11000. Now rename the design, open the flash memory menu and in the right hand pane you should see your usb flash drive, if it's the only one you have connected all well and good, if not click on each flash drive to find the correct one.You'll know which one it is,because in the window below you will see an Embf folder, open it, you must always open the Embf folder before writing a design, now some have child files inside, emb, if so open that as well , don't create a new folder it wont be read by the machine. Now write the design to the usb flash drive. Do you have a copy of the PCtools software? if so you need to download the update as it's that software that allows 2 way communication between the machine and the computer. Keep an eye on how many designs you insert into the internal memory, it isnt very big. You shouldnt need to reformat the internal memory,
Jan 08, 2008 | Janome Memory Craft 10000
Janome Memory Craft 350E Embroidery Machine w/ FREE BONUS Logo
153 people viewed this question
Top Janome Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Carolyn Rogers
Carolyn Rogers
thinksewfast
Are you a Janome Craft and Hobby Expert? Answer questions, earn points and help others
