Question about Remington MB975
The head came off
Three pieces came off
Sculpture puzzle answers or solutions
If you can see a four digit code on each piece, the second number tells you in what part of the puzzle the piece should be. Example: All pieces with second number a three should be in the same "part" or area. Then You should take the two last numbers from the code and minus the first number, example 13-6=7 then this piece is the seventh piece in the third module. You will get for all modules pieces with numbers from 1 to 30 after some calculation. Put the pieces in order smallest most under and bigger higher up. And start with "module" 1.
This was at least how the puzzle should be assembled. I hope this helped you!!!
Jan 21, 2018 | Toys
Do not know how to put the razor heads on after cleaning
most simply snap on. i sit with elderly and have to clean these all the time. the small pieces inside come apart, but you simply put the round pieces back in first, thenthere should be a bigger piece to fit over all three small round pieces. simply line it up over the 3 round pieces, and turn slightly clockwise and it should click. once that is in place, simply take the two hinged looking pieces and push into the device where they line up, and it should just snap in place.
Nov 19, 2012 | Health & Beauty
What type of spark plug does a 2004 ford f350 have ( is it two piece) and are there any problems changing them on your own?
Yes big problems they break in half they are pretty long Napa sells a tune up kit 8 spark plugs a drill bit and heilcoil repair kit..
Aug 27, 2011 | 2004 Ford F350
The shower head is leaking badly around the outside rim of the head when in use. i removed centre fixing screw and found a number of broken pieces of plastic approx.three mil. longinside the head which was...
hiya:) wish i had something better for you but i think you should just buy another shower head. even if we could find the parts, which i doubt, after shipping & handling (because you will not find the parts at the store) they would cost as much as a new shower head. not to mention your time. hope this helps and good luck:)
Jul 27, 2011 | Grohe 27069 Relexa Shower Head Shower...
My 2001 jaguar s-type is overheating. does anyone
The top radiator hose should connect to the thermostat housing, bolted onto your engine. Make sure you get a new gasket.
Hope this helps... Good luck!
Jun 10, 2009 | 2001 Jaguar S-Type
Need special tool for air/fuel adjustment, where can i buy one at.
Gary JP4... remember that short piece of hose you used to get the screws out? Why not just use it to make the adjustments to begin with. I found a piece of refer icemaker hose to work great, but also flex fuel line hose for gas engines is also great. Just push in far enough to squeeze down over the head of the screw... No muss, no fuss.
Apr 30, 2009 | Poulan Garden
Phone is not playing my music through headphones..
throw your phone mad fello ha ha ha ha
Apr 17, 2009 | Samsung Cell Phones
Head of philips norelco speed xl fell apart.
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Dec 20, 2008 | Philips Norelco 8175XL Electric Shaver
Replacing Heads for 8140XL Norelco shaver
Hope this helps!
Dec 02, 2008 | Norelco 8170XLCC Electric Shaver
Changing a head gasket
that is a three piece head. you will need exsperiance and specialty tools to do that one
Jun 07, 2008 | 2001 Volvo S40
Remington MB975 Logo
22 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
