Question about Craftsman 2-Cycle Mini Tiller
Starting issue when I pull on the starting line the pulley turns but it doesn't have any effect on the motor
    Scholar:
  • 119 Answers
The starter gear inside the pull cord is not engaging
this is a non servicable part
approach supplier and buy a new pull starter
Posted on Apr 14, 2014
I have a Yard Man self propelled push mower the pull rope broke I replaced the rope but now it won't recoil . Please help me find out what is wrong. Thx.
OK first remove recoil unit off motor, Whats the pull start.
Next pull the rope all the way out.Watch the direction the rope pulling is turning. When the rope is pulled as far it can be put something in to hold pulley where it is. Cut off rope knot and remove rope.Then hold pulley remove what is holding it from moving then continue turning rope pulley in same direction until it stops.Then turn opposite way to line up hole in pulley and hole in metal shield and block. Then slide rope through holes and tie knot tight. Release pulley slowly and rope is going to retract just like new...
Aug 04, 2014 | Garden
I have a craftsman walk behind lawnmower and my pull string will not start the motor and it doesn't lock
The small metal peice is the engagment pawl, it sits into the plastic pulley, if it has come out the pulley will probably be damaged as well, you will need to remove the pulley securing screw and big washer, you should now see the slot in the pulley where the pawl sits.
May 12, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
Hi The washer will not spin at all. Thanks
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a washer to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
or try to follow this instruction
1. Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
2. Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
3. Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
4. Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
5. Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
May this help your problem.
Thanks good day!
Sep 12, 2011 | Kenmore 44102 Front Load Washer
Kenmore model 110.24642300. Basket/drum doesn't spin, though it sounds as if the motor itself is working fine. It isn't the latch on the lid. I think there's a belt or clutch issue inside. ...
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
First open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Also check this link to get a detailed idea related to your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | Kenmore 22422 Top Load Washer
Wcvh62604fww starts fills and drains but does not agitate or spin. It does turn the drum in the beginning to test the load
These symptoms appear to be a problem with the drive system which includes the inverter that drives the drive motor and of course the drive belt. Verify first if you can hear the drive motor running and if yes, the drive belt has broke or slipped off the pulleys. Remove the screws securing the rear access panel and pull it outward from the middle to access and check the condition of the drive belt. Reinstall it if possible or replace it if necessary. Wrap it around the motor pulley then on one side of the drum pulley and turn the pulley in the direction in such a way that the belt will wrap the drum pulley.
Turn the drum pulley and the motor pulley with and without the drive belt if upon checking, the drive belt is still on. It will be known if there's restriction in either of the motor or the drum that prevents the machine from agitating or spinning. Try to start the machine with the drive belt off if no restriction is found which indicates that either the drive motor or the inverter is at fault.
Check the resistance of the motor windings (normally around 6 ohms across each of the 3 phases;otherwise, replace the motor) if the motor still doesn't run with the drive belt off. Check the continuity of the wire harness connecting the inverter and the drive motor if the winding resistances are good. Consider replacing the inverter if no problem is found with the drive motor and the wire harness.
You don't have to accept or reject this post in order to add information or post comments and follow-up questions should you need further help. But accepting a solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 30, 2011 | GE WCVH6260F Front Load Washer
LAT9116AAE transmission belt slipping, replaced belt & still the same problem. motor is loose so to adjust tension, so am wondering if trans. is pulling to hard, ??? do these fail & is it cost...
Hello, Thank You for using FixYa. I will be helping you today. Sometimes the pulley becomes glazed.. Use some sand paper and rough up the pulley on the motor and trans. Also make sure the belts on on the righ grove of the motor pulley.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Washing Machines
Where is tdc on my 2001 dodge ram 1500
top dead center
ok look at your damper pulley its the pulley at the bottom of the motor
the damper pulley has a line cut in it
line the mark up with the degree marks
you want to put it on the zero mark
once you have done this you are on top dead center
also number one cylinder must be on a compression stroke
pull spark plug number one turn the motor over with your finger
over the hole when you feel compression that's when you line
up the marks.
hope this helps you
good luck
bob
May 06, 2011 | 2001 Dodge Ram 1500 Truck 2WD
How do i fit the replacement belt as i cant see how to adjust the motor
hello,
There is no adjustment to the motor,if you have the correct replacement belt then these are stretch fit belts.Firstly hold belt onto motor pulley then slowly turn onto main pulley whilst still holding on motor end you may find one side of big pulley easier than the other.It will take a lot of pulling round onto pulley and you may think its too tight but keep turning till its on then line it up in centre of main pulley.
Hope this helps,
May 18, 2010 | Zanussi ZWF12070 Front Load Washer
The motor just humms loudly when I try to start it. If I give it a push it will start spinning, but boggs down if I put any food through it
Take the bottom plate off to expose the motor, drive belt, and pulleys (pull the power plug for this). Remove the drive belt and turn the motor shaft by hand--does it seem to turn freely? Do the same with the driven pulley--it should turn freely also. The pulleys and belt are likely cog-type and not prone to slippage. If either pulley shaft is excessively hard to turn, then investigate the reason,and replace parts if necessary. With the belt off, the motor should accelerate almost instantly. If relatively slowly, the motor may need to be replaced.
Jan 31, 2010 | Kenmore KFP-70 Food Processor
How do I rewind my starter rope?
hi you need to wind the spring to put tension on it depending on the type of recoil starter it is faily easy or dam near impossible "nothin is impossible "
take the compleate starter assembly off the motor and undo the rope from the starter / fit a new piece of rope 12 ins longer than origonal turn the center piece anti clockwise 2 turns ,this will wind the spring up wind the new rope on to the pulley put the handle on so you can feel it pull back and knot it so it has tension on it hpoe that helps merlin v12
Aug 16, 2009 | Air Tools & Compressors
Craftsman 2-Cycle Mini Tiller Logo
93 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
