Question about Drive CPN22FBA-POM 22" Cirrus Plus Folding Power Wheelchair w/
Wont start Beeing siting 4 about 2 yrs and now it wont start the horn works but wont start.
  • 932 Answers
Jose, I would guess from your comments that it has not been on the charger during the two years sitting and if that is the case most batteries will hold some charge and that is why you have the horn working, but there is not enough voltage to actually run the chair. I would recommend that you take the batteries off the chair and take them someplace like Auto Zone or a car mechanic that has a battery tester and have them charge it up and load test the battery and that will tell you if it is any good still or if you need to get new batteries. Hope this helps.
Posted on Mar 26, 2014
Horn does't work on my 2000 buick custom motor car
start by checking fuses and horn relay, next check the ground on the horn it self, and if it still wont work you may have to change horn ,to check horn just put power to where horn power would go to it ,it should blow .
Mar 01, 2015 | Buick Cars & Trucks
Anti theft on 2006 Impala is causing horn to honk continuosly and keeping it from starting
unplug wire from horn and check relay or fuse it will still cause the car to start but your horn wont work may have a short in your horn,
Dec 15, 2013 | Chevrolet Impala Cars & Trucks
Briel two241 brand new from Amazon - wont start?
hopfully its just a battery, they only last 2 yrs, swiss is 3-4 yrs.if battery dont work , could be circuit or mechinec's of watch, repalce movement .. if new send them back. battery changes may be remeburst
Jun 17, 2011 | Briel Watches
Horn wont work on my peugeot partner van
Check (in the order, presented below)
1. horn fuse
2. horn relay
3. horn circuit (you will need tester)
4. horn itself (remove it from car and connect to 12V DC)
May 19, 2011 | Peugeot 405 Cars & Trucks
Horn blows when it want to, makes a clicking noise i hear inside the car when i go to blow it but it wont blow and where is the horn located ,0n this 1994 buick centry and how can i fix it ,im 70 yrs old...
The problem is most likely not the horn, but the horn relay. Go to your nearest "Auto Zone" or O'Reilly's and they can not only sell you the new horn relay, but very probably show you where the old relay is located.
Mar 28, 2011 | Buick Century Cars & Trucks
Hello; i have a 1971 honda cb750K1,the horn is not working,everything checks out (have power to the leeds) when button is depressed, is there a way to remove horn cover without damaging it to inspect...
Hi there and welcome to FixYa,
Wow that's a vintage bike. Nice.
The coil is probably burnt and there's no way to fix it but replacement. You can try to pry it open to replace it with another horn but it would only ruin it. A vintage horn should be replaced by a similar horn.. I found you a site where you can order the replacement part.
http://www.davidsilverspares.co.uk/CB750K1-FOUR-1971/part_104676/
Hope this helps,
levibit
Dec 25, 2010 | 1971 Honda CB 100
My 200 jeep cherokee classic's horn wont turn off?
In the PCM is where the Horn Relay is. It's location should be annotated on the underside of the cover you pulled off to gain access. One way to determine if it is the Relay or not is to find a similiar Relay (shape and size) and switch them. If this fixes the Horn problem it is the Relay and should be replaced.
Dec 21, 2009 | 2000 Jeep Cherokee
Electric Start Wont Work (Four Wheeler)
Solenoid Faulty or loose connections, short out the solenoid on its contacts and see if this throws on the starter motor, other than that it could be brushes inside the starter motor itself. Good Luck , the eti
May 20, 2009 | 1979 Yamaha RD 250
Horn blowing and car wont start
Same problem on 98 Jetta at about 9 yrs of age.  Wiring harness was an expensive job.  Dealer replaced all wires going to doors so that alarm isn't mistakenly triggered by opening doors.  Dealer offered to remove alarm for a few hundred dollars, but couldn't assure us that the key fob would still open the door locks.  Who wants to give up power locks? My hunch is that wire in driver's door breaks with flexing over 9 years.  Could consider replacing short stretches of wire in hinge of drivers door if you're handy with a soldering iron.
Jun 14, 2008 | 1998 Volkswagen Jetta
Drive CPN22FBA-POM 22" Cirrus Plus Folding Power Wheelchair w/ Logo
61 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
