Question about EdgeStar Kitchen Appliances - Others
Mr freeze ice machine parts ice sensorthe unit never starts just shuts off
Ice sensor blinks on and off sometimes... the unit never starts just shuts off
    Sergeant:
  • 230 Answers
It believes that the bin is full. You will need to clean the sensors. Should be a couple of eyes under where the ice drops. Or if it has a door, check to make sure the magnet is still in the door.
Posted on Apr 13, 2014
E4 Error Code
Could be overheating and a sensor is triggering the machine to turn off or it could be short of gas. Check all pipework connections for tightness and especially look for oily residue on any of them. This would indicate a leak. Unfortunately, if there is a leak, you would require a licensed air con Tech to repair the leak and regas it.
Apr 09, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine manual
Ice thickness sensor dirty or faulty, fooling machine into thinking ice on the plate
Mar 12, 2014 | Kitchen Appliances - Others
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
I have a Scotsman Cm3 which will not stop making ice. When I come back to work in the moring and open the door, ice falls all over the floor. Is there a way I can fix this?
Is the ice building up into the ice head enough to break the beam on the bin sensor. if so replace the sensors. if ice is not up far enough shut machine off remove plastic grid reach in and down to where bin sensors are and watch to see if light blinks on and off if so they are good. next step check the bin there should be a white ice deflector with 3 thumb screws in the top of it make sure this deflector is mounted so it makes the ice build up high enough to cause ice to reach bin sensor. if the sensor is not seeing ice then it will let the machine keep making ice. If this is all working good then replace the service controller but make sure you look on the back to set the right model program for your machine.
Sep 16, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Mr Freeze SA12863 Counter Top Ice Maker parts?
Call the phone number on the back of the machine.
sunpentown 800-330-0388
They helped me diagnose a problem and sent me easy instructions for fixing it. They also had parts I could order.
Apr 22, 2008 | Refrigerators
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Indoor unit comes on for 5 seconds and then shuts down
"Off" the circuit breaker and then "on" again then start the unit .
Oct 08, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Kitchen Appliances - Others Logo
274 people viewed this question
Top EdgeStar Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an EdgeStar Kitchen Appliances - Other Expert? Answer questions, earn points and help others
