Question about GE 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25ARBWW
GE Fridge TFX25JRYDWW water tastes bad and ice is dirty
My GE Fridge TFX25JRYDWW has horrible tasting water and the ice has some weird green material on some of them.
  • 331 Answers
Have you replaced the water filter?
Posted on Jun 15, 2009
  • Roxanne McGruder
    Roxanne McGruder Feb 26, 2016
    Where is the water filter for this refrigerator??? I looked everywhere inside and outside!!
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Bad tasting ice/water/food
Have you put a few boxes of baking soda in the fridge to absorb the pungent odors? Do that.
Jul 07, 2017 | Kenmore Side by Side Refrigerator
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
Our new Samsung fridge has horrible tasting water
add water filter system to the unit ..
if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer burn on ice-cubes
Black mould around the freezer seal is normal if it has built up over a long period of time or has stood in damp environments. Normally hot soapy water can clear this right up. The ice taste would probably be resolved by fitting or changing the water filter, and / or cleaning the ice maker module located at the top of the freezer section and any route that the ice would take. Cleaning solutions for ice makers are available you just might need to call a local engineer for some advice on where to get some in your area. Hope this helps.
Feb 07, 2008 | Refrigerators
Water and Ice have a horrible taste.
Thats becouse the instaler use cooper line, in a short period will taste beter and beter, but I don use cooper becouse that I use rubber or plastic make it change and let the water run for a waile...good luck and rate me...
Jan 20, 2008 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
801 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
