Garden Logo
A
Anonymous Posted on Mar 26, 2014
Need18vslideon batterychargerforepc182-xedrill need a replacement slide on battery charger for a black & decker 18 volt drill model no. epc182-xe
betyar_is
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Mar 26, 2014
betyar_is
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
29898
Points
26
3helpful
2answers
18volt cordless drill battery charger will not charge batteries
Fist you should check that if there is problem with your battery or charger. Do you store your batteries in right way when you don't use them?
You can come here (Power Tool Batteries Drill Batteries Replacement) and find if there is batteries or chargers for you.
Mar 26, 2014 • Drills
1helpful
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
3helpful
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
2answers
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
1helpful
HI Can i still get a 1hour Ni-Cd battery charger Battery Model 5100235-09 if so where would i be able to find it . Thanks
if you could, i would check black and decker .com you can find parts and service centers close to you.or maybe at a battery depot
Can you use the 9 volt charger with the drill that says it takes 7.2 volts. This is the charger that came with it
THe charger should match the voltage on the battery or you will damage it. A 9 volt charger should not be used on a 7.2 volt drill.
1helpful
1helpful
Charger not charging have 2 new chargers neither 1 will work for black& decker 18 volt cordless
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Schematic / service information for Black and Decker VP 130 battery charger
Power supply for the VP130 is a 4.32v 210ma AC transformer.
The AC supply is fed to the charger battery box where there are two diodes one for each battery.
each battery is 3.6 volts.
Top Garden Experts
Jay Finke
Jay Finke
john h
