Question about SECCO WVPOLSET 4-Inch Variable Speed Wet Polisher Kit
Broken handle How do I order a new handle for the secco wet polisher
What makes the wet n wild nail polish oppsite than other nail polish
You get what you pay for. Wet & wild is cheapest polish. The polish doesn't last as long as the expensive kind
Jan 04, 2018 | The Health & Beauty
Problem with my MK1503S Wet Polisher. It 's dead. Could it the motor ??? Haven't been working for a while. I am wondering whst the part number is and how much it cost? Thanks, jhechanova
1; verify power exists @ recipticle.
2; verify plug and cord on polisher don't have any issues, ie: cuts in cord, a connection that has come loose, broken wires,etc.
3;if you havn't found any issues in 1 & 2 now we look at the switch, you can put leads from an elect. meter on the termination points of the switch to veriffy all is good.
4; Now we chk from switch to motor, this is also easiest with a meter,
If you can try some or all of these we can move forward with more diagnosing
Nov 01, 2010 | Mk Diamond 157493 Mk 1503 S Wet Polisher...
The handle release button is broken/ the handle will not fold
If you go to this URL:
http://www.ereplacementparts.com/eureka-2590a-carpet-cleaner-parts-c-108750_109432_109471.html
you should be able to identify the part and order it as well.
If you find this solution to be helpful, I would appreciate a Thumbs Up rating from you.
Be well, Paul
Oct 06, 2010 | Eureka Atlantis 2590A Wet/Dry Vacuum
Porter cable polisher5 7424 only works at max speed
it could be that the variable speed module is malfunctioning. If it is the part number is 886978 and lists for 12.27. I would check for a buildup of polishing pad inside the handle area and clean thoroughly before ordering any parts. You can view a breakdown at Dewaltservicenet.com
Oct 07, 2009 | Porter Cable 371K Electric Sanders &...
1997 buick park ave 4 door right front door handle won,t work from the outside
Order the exterior door handle AND the clip that attaches the rod to the exterior handle from your local dealership ( any part in the salvage yard will have at least as much wear as the one U are replacing ) Also order a can of touch up paint matching your car. After you have the parts and have painted the new exterior handle, roll down the window and remove the interior door panel. ( instructions have been posted at 'replace door lock buttom' ) Two nuts, one on each side, hold the broken handle in place and must be removed ( DON'T loose them ). Loosen the rod from the clip at the top to allow a bit more room, But take note on the way it is attached ( you will need to reattach the rod to new handle ) To install new mechanism put the new clip on the rod, carefully place the gasket and the new handle in place and install nuts to secure. Test the door handle and make sure it works. Reinstall interior door panel.
Jul 06, 2009 | 1997 Buick Park Avenue
How do I replace xc90 headlight assembly?
its really easy. Open the hood, you will see two metal flat bars on the backside of each headlight, holding the headlight assembly on. Pull up on each of them.... remove headlight. Ta da.
Sep 19, 2008 | 2004 Volvo XC90
Circular Polishers question
Circular polishers can remove any damage that does not penetrate below the clear coat. This includes scratches, oxidation, and paint swirls
Aug 27, 2008 | Makita 4" Electronic Wet Stone Polisher
Broken handle release
Most times they don't break, it is the 2 screw holes at the back that back and the top will raise up from the base. If this is the case, remove the 2 screws and install longer ones with a flat washer on them to fashen down the top. But first the top will have to be removed to put the handle release in the right spot. You would probably look at around $60 to repair, unless the top needs replaecment, then it would be more parts.
Apr 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
SECCO WVPOLSET 4-Inch Variable Speed Wet Polisher Kit Logo
22 people viewed this question
Top SECCO Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a SECCO Tool and Hardware - Other Expert? Answer questions, earn points and help others
