Ford raider engine number
Where is the engine number on a ford raider 1993
  • 132 Answers
SOURCE: wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Posted on Jan 03, 2008
SOURCE: 1993 ford ranger supercab
the fuse box is inside the pickup under the drivers side dash, there is a flasher which is the round one in the fuse box, it controls turn signals and emergency flashers also in the same fuse box, there is a 15 amp fuse which controls just the turn signals it sits vertical instead of horizontal.
Posted on Oct 23, 2008
outdoorsman5
  • 631 Answers
SOURCE: 1993 Ford F250 engine quit
Yes that is possible. Did you try and hook up lines together that go into the valve to see if it would run. Also check to see if there is fuel to injectors.
Posted on Jul 28, 2009
johnjohn2
  • 5763 Answers
SOURCE: 93 ford aerostar 4.o engine head bolt torque
step one is 22 ft lbs.
step two is 52 ft lbs
step #3 is turn an additional 90 degrees. sart in the middle and work your way out going top tobottom, good luck.
Posted on Nov 03, 2009
Testimonial: "thanks very much. I thought that the "90 degrees" on the gasket instruction sheet was a misprint. Your answer was quick and informative. G.M."
  • 1596 Answers
SOURCE: my 1993 ford Taurus is running rough drives a
If it has NOT had a TUNE UP In A Long time THIS is MOST Likely the CULPRET as what you discribe ALL can be attributed to POOR TUNE Up PARTS.
Posted on Nov 14, 2009
I am looking where to find the engine number on a Ford Ranger 1993 4.0 V6 engine?
Engine identification label is usually found on the valve cover:White plastic tag with (1g944aa-xx)or someting like that.
Jan 07, 2011 | Ford Ranger Cars & Trucks
What is the spark plug gap on a 5.0
Make: FORD
Model: F-150 - SUPER CAB
Year: 1993
Engine: V8 - 5.0L - FI - - GAS
Part Number RV15YC4 - OE GAP .044" (Original Equipment Manufacturer and/or Original Equipment Equivalent)
Hope this helps (remember to rate and comment this). Good lukc.
Nov 12, 2010 | 1993 Ford F150 SuperCab
Where is the engine number on a 1988 ford telstar sedan
Where is the engine number on the 1993 Ford telstar 2.5 v6
Sep 02, 2010 | Ford Aspire Cars & Trucks
Need head bolt numbering for 1993 ford 1.9L engine. already know sequence, just don't know numbering of bolts on head.
Hope this helps
Front to Rear Diver Side
8-6-2-4-10
Front to Rear Passenger Side
9-3-1-5-7
Aug 27, 2010 | 1993 Ford Escort 4 Door
I HAVE A 1993 FORD RANGER 3.0 V6 ENGINE AND NEED
For 1993 Ford Truck Ranger 4WD 3.0L MFI 6cyl the Control Module-Ignition is located under hood, center, rear engine area, mounted on distributor.
Fig. 1: View of the remote mounted Ignition Control Module (ICM)
Hope this help (remember comment and rated this).
Jul 27, 2010 | 1993 Ford Ranger SuperCab
93 to 95 Ford F-150 V-8 engine....firing orders!
Here are the firing order diagrams for those engines and I hope that they will help you solve the problem that you are having. For some reason Ford has listed the same firing order for both engines starting in 1995.
1993 5.0 liter engine firing order.
1993 5.8 liter engine firing order.
1994 5.0 liter engine.
1994 5.8 liter firing order.
1995 5.0 liter engine.
1995 5.8 liter engine.
Jun 16, 2010 | 1993 Ford F150 SuperCab
Ford Festiva engine number
The Engine Number is Coded Inside the VIN Number. Write it down and Contact your Closest Ford Dealer and they can tell you Just from your VIN Number.
Jan 12, 2009 | 1993 Ford Festiva
1993 ford explorer - toublshooting fuse/electical problem
I believe the fuse for your starter is in the power distribution box, 93 explorer 4.0L 4X4. find diagram for this in Chilton Ford Ranger/Explorer/Mountaineer 1991-1999 Repair Manual 26688 page 6-43 Fig.88 Be aware that there are (4) figures for the 93 4.0L explorer and each shows a different part of the same engine wiring. See top right 'power distribution box' follow lines to the part of your engine you are concerned with, which fuse number, then look inside your engine, passenger fender, push down on the protective ?wall then pull the cover up, see your diagram and fuse numbers. The diagram for inside fuse box, page 6-31 fig.63 I hope this helps
Jul 05, 2008 | 1993 Ford Explorer Limited
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
