Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
Sony KP-57WS520 57
My tv standby light blinks 9 times, what does this mean and how do i fix it?
  • Sony Master
  • 8,617 Answers
Diodes are blown on the G board ( POWER BD) replace the G board.
Posted on Jun 15, 2009
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
TV won't turn on, standby light just blinks 9 times
hello, Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
regards
shaun
Oct 19, 2010 | Sony KP-46WT520 46" Rear Projection...
TV won't turn on, standby light just blinks 9times off and on
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
Feb 03, 2010 | Sony KP-46WT520 46" Rear Projection...
Red stand by light blinks 8 or 9 times and no picture or sound
hello Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
shaun
Oct 18, 2009 | Sony KP-51WS510 51" Rear Projection...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV will not come on. TV standby light blinks nine times continuously. TV is Sony KP-51WS520
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Mike
Apr 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
How do i fix my sony kp-46wt520 projection tv
Called sony and they said send it so we can help fix it.
Mine was a bad "g board"
Sent it to PA (penssylvania)
And they fixed it for & $88 you have to ship G-Board to them and they will return after they fix it if not repairable they will tell you.
(No charge until they fix it.. )
Mine works now and ready for superbowl....YEAH ! ! ! !
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
Jan 13, 2009 | Sony KP-46WT520 46" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
413 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
