Question about HP Pavilion xt938 PC Desktop
No sound but when i test it has sound ?
The sound in not paly in my pc
Posted on Jun 15, 2009
Yamaha DVX-S100 Theater Sound System
check your surround sound settings. Switch the speakers and test it again. if the problem persist, take it to your store and ask them to test it.
Jan 18, 2014 | Yamaha DVX-S100 System
People can hear me but I can't hear them
Does your sound card work? Did you run the sound test in SKYPE? In the options section, click on Sound Devices and select Make a Test sound. If that works, click on Make a test call.
Good Luck, Jim
Feb 22, 2011 | Skype IM
I got no sound and my mic don't work when i try in the chat room it saids voice error
install your sound driver properly after test your sound. u can test your sound by going in control panel and opening sound icon.
Feb 19, 2010 | Computers & Internet
DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
Apr 28, 2009 | Creative Labs SoundBlaster Audigy 2 ZS...
It sounds like you may need to Update the Drivers. If not you may have a Bad Sound Card.
Jan 22, 2009 | Computers & Internet
Can't hear my sound playback on sound test with skype
After you install Skype and have it operational with you ID . Go to "TOOLS", click on "OPTIONS", nect go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correct Then "make a free test call" .Wait till the voice tells you to record. Then when finished talking waite for the test voice and the test persons voice to insue you audio transmition is work. Then go back to options and test your video.setting. Click on Video Settings and procede to set up you video camera. Also Visit this site to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Jan 05, 2009 | Logitech Quickcam Chat Webcam
My speakers do not work anymore in my inspiron 2200
If you press Fn while powering the system on it should enter diagnostic mode. It will perform some memory tests and then present a video test screen at which point it plays sound through the speakers. If you here this sound, then your hardware is functioning and it is a software problem. There are USB sound cards available - note: you would need external speakers as well.
Dec 26, 2008 | Dell Inspiron 2200 Notebook
No sound from it.
I guess it was working all along, but simply would not respond to the test sound from my Onyko. But when I put in a DVD it is definitely putting out sound. So I don't know why it will not respond to the test sound because all the other speakers respond to the test sound. ???
Thanks.
Dec 06, 2008 | Infinity BU-2 Speaker
Unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Jun 08, 2008 | RCA TruFlat 27F520T 27" TV
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
