Question about BAK 2001 Ford F-150 - XL, 6 6" short bed, standard box - ProCap Bed Caps
2001 ford f-150 xlt tail gate wont open
Tail gate is jammed
Sticky tailgate handle on 1995 f-150
Can you push against tail gate and it opens easily use wd40 on latches then work the handle open and shut tail gate then respray with wd40
Oct 22, 2016 | Ford F-150 Cars & Trucks
Tail gate is jammed. How can I open it?
If you cannot open it, after trying a few days, then you might consider getting a sawzall and cutting the posts and once you have it opened replace the posts (from a junk yard).
Aug 05, 2010 | 1985 Ford F 250
Need to replace bulb in tail light on 2001 150 FORD pickup
drop tail gate ,,their should be two screws on tail gate seam,,remove them,,tilt lens out,,
Feb 13, 2010 | 2001 Ford F150 Styleside SuperCrew
Donde puedo encontrar los 5 numeros del keyles entry en el auto
OPEN THE TAIL GATE ON TH INSIDE OF THE TAIL GATE SOME TIME THEY PUT A LITTLE STICKER WITH THE NUMEROS.
Nov 06, 2009 | 2001 Ford Windstar
Tail gate will not open
need to unscrew the main latch and reset
Oct 14, 2009 | 2001 GMC Jimmy
Cannot open the rear lamp to replace globe
There are 4 screws to hold the rear lamp on. Two are in the lens at the side...the other two are seen when you lower the tail gate.
Hope this helps.
Aug 18, 2008 | 1993 Ford Ranger SuperCab
Chevy blazer 2w drive 2 door-rear gate wont open
you will need to try to remove the rear door panel on the tail gate or pry it away its not easy because of hidden screws the manually pull the linkage
Aug 16, 2008 | 2002 Chevrolet Blazer
Tailgate lock assist will not work
my v70 vovlo estate(2000) tailgate wont open.checked fuses ok.no sound from mechansim when key fob depressed as the others do.Cant get into the back panel or open door at all.can you help with a suggestion?
Aug 05, 2008 | BMW 525 Cars & Trucks
BAK 2001 Ford F-150 - XL, 6 6" short bed, standard box - ProCap Bed Caps Logo
21 people viewed this question
Top BAK Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a BAK Air Tool and Compressor Expert? Answer questions, earn points and help others
