Question about Logitech Cordless Mouse
Mouse does not respond
Light doesn't come on
Logik LMWLPP13
I would still try changing the battery. Even if the light in the mouse is still visible, the battery voltage may have dropped.
Feb 26, 2014 | Computers & Internet
Mouse buttons spontaneously click themselves
I'm afraid that keyboards and mice don't like tea much at all. You can pick up keyboards and mice cheap enough and to be honest they are just not worth repairing. Even a tin of Servisol Video 40, which you can spray on the contacts to clean them will cost you as much as a mouse would!
Mar 12, 2017 | Logitech Cordless Mice 910001822 M510...
Dot s touchpad not responding
Use an usb mouse to select control panel and then select device management. From there you need to select the mouse and from there select the mouse and right click on it. Select to uninstall the device. Then close all screens and shut down computer. Unplug the usb mouse and restart the computer. If after it completes loading and it doesn't work the you will need a new touch pad. But if it does work it means windows had an corrupt update which caused the problem. Thanks Igor!
Sep 29, 2012 | Computers & Internet
Not responding
Ok try to reboot your pc, but if you have already did it try to connect your mouse to other USB port preferably at the USB port at the back of your PC..If still doesn't solve the problem perhaps your mouse already needs a replacement..
Jul 08, 2011 | HP DC172B Mouse
USB light for microsoft 3000 wireless keyboard/mouse not turning on. Keyboard and mouse not responding at all. Tried everything I could think of.
Go to Microsoft/help/support.com and you should find a solution. Sounds like you don't have the right hardware or a bad software pack. Also make sure the computer recognizes it. Try another keyboard if you have access to one. You'll probably have to go to another computer to get instructions and print then out and maybe you can do it with a mouse if it works and another keyboard doesn't work. If you can get another keyboard to work and download the drivers for the 3000 make sure the 3000 is plugged into the computer when you download the driver for the 3000.. They do have downloads for the 3000 I just went and looked and the last keyboard I had was a 3000 and I downloaded files from Microsoft. Hope this cures your Microsoft headache; dhgill1949
Jun 04, 2011 | Microsoft Wireless Desktop 3000 Keyboard
I have a Mini Wireless Optical Mouse. M/N M-RAD92. I just changed batteries. The mouse is lit up, but the USB port stick's light will not light up and the mouse is no longer worker.
usb stick doesn t light also on mine but works perfectly. press once on stick button and once on mouse "setup" button and they will connect.
Jan 31, 2011 | Labtec Wireless Desktop Keyboard/Mouse...
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
PS2 KEYBOARD & MOUSE Not responding.
Try connecting one at a time, if you connect the mouse don't connect the keyboard, and if you connect the keyboard, don't connect the mouse, reboot each time and check which one is the culprit. One of the port or device must be creating the problem. Good luck.
May 24, 2010 | Asrock CONROE1333-DVI/H INTEL 945G CHIPSET...
Logitech Cordless Mouse Logo
16 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
