Question about Olympus Camedia D-395 Digital Camera
Has batteries installed but won,T TURN On. does this camera require sd card to work
Will not switch on
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Switch sim card
Your SD card is for your memory check your battery
this is what you check... turn off your camera Take out you battery charge and replace... Take out your SD card replace it correctly. Remove your lens and replace correctly then turn on camera and walla it works! PS its ok to leave the SD card in the camera. The on and off switch turns on camera with a charged battery ELEMENTRY WATSON.
Nov 19, 2013 | Nikon Cameras
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
My camera won't save to mass storage
Are you sure it's an SD card? If it's larger than 2GB then it's actually an SDHC card and won't work in the A300.
May 06, 2012 | Polaroid a300 Digital Camera
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
New Jazz DV150. Installed new batteries (tested) and SD card (tried switch in both locations). Powers on, says "Read card....", "Goodbye", powers off.
HI, I just got off the phone with a very nice man in NJ at Digitac. He walked me through a few fixes: Try a different SD card, clear SD card, put SD card in and then start camera, start camera and then put SD card in. None worked, so he said something is wrong with the camera computer and I will have to send the camera in for warranty work.
Feb 28, 2011 | Jazz DV150 Camcorder
DSLR do not power on
It's almost impossible to accurately troubleshoot a "dead" camera without seeing it, but your problem could be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Oct 20, 2009 | Pentax *ist DL Digital Camera
Sd card cannot be read & internal memory of camera cannot be read
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Oct 01, 2009 | Kodak Cameras
Hi,just bought a 4gb sd card for my digimax s600 but it won,t work.when i switch on camera, screen says..format..yes.confirm ok.when i do this i get check sd card . i put in old card it works fine??..
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Sep 09, 2009 | Samsung Digimax S600 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Olympus Camedia D-395 Digital Camera Logo
21 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
