Question about Troy-Bilt Troy-built Tb516ec 4-cycle Gas Lawn Edger 9" Dual-tip Blade Authorized Dealer
Can not get blade locking nut off of lawn edger
How to remove blade locking nut
2 Suggested Answers
  • 51 Answers
SOURCE: How do you keep the
stick a block of wood inbetween blade and sheild or spacer behind blade may have a hole to put a punch or nail to keep from turning. hope this helps
Posted on Aug 15, 2010
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
Can not remover edger blade which way do you turn nut seems to be frozen
Spray that ****** with some penetrating oil like PB Blaster or Liquid Wrench and let it soak on it overnight. The locking nut probably removes counterclockwise. Maybe use the exact corresponding hex-head socket (6-Pt. not a 12-Pt.) and ratchet and give the handle a good strong rap with a hammer when it is ready.
Nov 13, 2010 | Craftsman Garden
Unable to get nut off of a craftsman convertible edger.
Lock on the blade with a pair of ViseGrip Pliers, then try turning the nut, they are installed quite tight, also try clockwise, maybe left hand nut.
May 25, 2010 | Craftsman Convertible 25cc. Gas Line...
Is the nut for blade removal right hand?
on blade removal it is opposite. Lefty tighty, righty loosen
Mar 29, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Cannot stop the shaft from turning to remove lock nut fs400 to remove brush cutter blade
With unit in normal operating position, the operator can see the small hole on top of the gearbox. Insert a blunt ended metal dowel rod into that hole to lock the gearbox and remove the cutting attachment. NOTE: The locknut is left-hand thread.
Sep 20, 2009 | Garden
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
I have the Toro edger/trimmer combo - which way does the edger blade bolt turn - I tried counter-clock-wise it won't budge. Also how to the LOCK the blade from turning??
on blad removal the nut goes opposite to tighten, lefty tighty, righty loosen. Put a metal wrench or rod in between the blade and the guard to keep the blade from moving.
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Can't remove the nut holding blade on. Which way do I remove
Get some WD-40 and spray the area around the nut then let it sit for a few hours. This will get into the threads and loosen any rust that is compounding your problem. Now get a good wrench and look directly at the nut. Left is loose and Right is tight.
May 21, 2009 | Craftsman Gas Mini - Tiller/Edger
Troy-Bilt Troy-built Tb516ec 4-cycle Gas Lawn Edger 9" Dual-tip Blade Authorized Dealer Logo
37 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
