Question about Vaico 2004 - 2007 BMW 525i Auto Trans Oil Cooler Thermostat W0133-192
2004 bmw 525i
Fault code 4E23 electronic pressure valve 4, do i need to change the whole gearbox or valve body.
Where is the trans range sensor located on a 2004 BMW 545 I
BMW transmission range sensor position Vehicle Parts ...
www.fixya.com/tags/transmission_range_sensor_position/auto.../bmw
BMW vehicle parts & accessories transmission range sensor position related ... i got a transmission fault warninig my bmw car 545i E60 it is a 2004 E60 bmw car ...location transmission dipstick 1997 bmw 328is if its a manuel transmission it ...
P0705 Transmission Range Sensor TRS Circuit Malfunction
www.obd-codes.com/p0705
Transmission Range Sensor Circuit Malfunction (PRNDL input) ... Later models with the transmission range sensor located in the valve body are a different ball ... What causes the P0705 code on a BMW 740i ('97) ... 2004-2015 OBD-Codes.com.Missing: 545
Nov 25, 2015 | BMW Cars & Trucks
I have a 2005 BMW 745i. It won't come out of park. Someone mentioned that there is not enough pressure because a sealant need to be replaced in the transmission shaft. Is this a costly repair, and will it...
Hi normally most E39/E60 BMW electronic gearboxes have a safety lock connected to foot brake which restricts gear selection unless driver apply;s foot brake.this could be a possible fault ,gear linkage have come loose,otherwise internal gearbox fault ,this will require a full diagnostic fault code report to determine that faults are permanent or intermittent . low transmission oil level can cause this problem.
Jan 07, 2015 | Cars & Trucks
How get to P0755 fault Jaguar shift solenoid .
that fault code relates to a internal component failure inside the gearbox, or a wiring problem from the powertrain controle module to the gearbox, it all depends on the gearbox that is fitted. if the gearbox has a plastic sump pan the controle module is part of the gearbox, the shift solenoid moves a valve inside the gearbox to direct fluid pressure to the relevant servos to control gearchanges e.t.c.does the car still drive?
Dec 26, 2014 | 2000 Jaguar S-Type
What Gearbox should be in a 1991 BMW 525i E34
The safest way for you to know which gearbox fits your car (second hand) you first have to go to a parts shop with your VIN and get the code and the model for your gearbox.
Don't just rely on car year and engine power.
Hope this helps
Jul 23, 2014 | 1990 BMW 525i
2004 Jaguar X-Type AWD 3.0 65,000 miles. It starting shifting rough and I got a gearbox fault message on the dashboard. At the same time, the transmission fluid started leaking. The garage couldn'
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Antilock brake system.TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module
Oct 17, 2012 | 2004 Jaguar X-Type
Transm fault just showed up on my 2004 BMW 525 I. What could this be. Anybody with any idea
A fault code detected form the transmission and determining cause can be from a actuator a solenoid to a fuse or a sensor.
Feb 29, 2012 | 2004 BMW 525i Touring
My Automatic transmission gearbox is not driving normal please i need an interpretation po751
Hi there!
the code P 0751 Means you have a problem with the shift Solenoid valve (A) and sometimes it get stuck open or closed and it doesnt let the valve shift as it should and its an electronic problem and this could happen anytime with warning, and when the problem is detected , the code gets stored and it doesn't mean that it needs changed this might happen ones then it gone. So all I can say is if you are experiencing this problem then have your fluid flushed and change the filter too and hope this will wash any dirt that could have built inside the Valve body of the transmission , and if the problem is not solved then you might need someone who works on the transmission to change the Shift solenoid valve which is located in the valve body of the transmission. Good luck bro
Jan 30, 2011 | 2004 Land Rover Range Rover
Vaico 2004 - 2007 BMW 525i Auto Trans Oil Cooler Thermostat W0133-192 Logo
212 people viewed this question
Top Vaico GPS Experts
Are you a Vaico GPS Expert? Answer questions, earn points and help others
