Simpson washer 36s550
All water tempreture lights are flashing and beeping and nothing is happening
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
  • 713 Answers
SOURCE: My Simpson Eziset 550 won't
Hi just read your posting.Now in your posting you said there were 2 lights flashing.What lights are flashing?Also on a sticker at the back of the machine there is a model number.Could you please reply back and let me know the model number and which lights are flashing.Looking forward to your reply.
Posted on Aug 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Lid lock light beeping continuously and flashing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: simpson encore 605 won't start
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question !!!!
SOURCE: my Simpson eziset 800 washing machine will not
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Posted on Dec 18, 2010
Why does my washing does a full cycle and pumps the water out but wont spin
http://laundry.manualsonline.
It seems that the carbons are worn
They are either side if the motor and kept by two springs
They cannot touch the core hence no spark
Put your machine on spinning mode while empty if it does it means the carbon are too weak to do so while when the washer is full of water
If the machine has not got carbons then it is the motor itself
Just check on the site and you will find details of your washer
Sep 15, 2014 | Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Simpson 36S550 wouldn't drain, spin or wash but light comes up and says it is in progress.... Changed PCB but realised the new one I got is different version to the old one but company recommends the same...
There can be some changes that are prescribed when a new version is set in and you must consult with the company to clarify this before we damage the new board. If not the fault seen is still within , check the inlet flow, the water level controller and the drain pump.
Aug 22, 2013 | Fisher and Paykel IWL12 Top Load Washer
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
My washer keeps flashing f24 and wont turn on what does it mean?
Hello, This is a water tempreture sensor error due to if the tempreture sensor value is out of range during the water heating up step during the cycle. Unplug washer or disconnect power, Check the water tempreture sensor and connection to it,check the resistance of the heating element using a multimeter. If you have any further questions message me back this error code diagnosis is for a whirlpool duet washer if you happen to have a different type of washing machine message me back your make and model number of your machine. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Aug 18, 2011 | Whirlpool Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
Nov 08, 2010 | Siemens Washing Machines
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
