Question about DeLonghi KH190920 Oil Filled Radiator Heater
NEED INSTRUCTIONS MANUAL
IT HAS 3 SETTINGS AND A TIMER AND FOR THE MODEL ECT.. IT ALSO HAS THESE LETTERS- HORK
Just need directions to print off
not sure if this will help you at alI, but I found this answer on the following website: .askmehelpdesk.com
and an answer to a similar model here: http://www.intermatic.com/images/misc/158ej12685ref.pdf Good luck
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off
Jan 02, 2015 | Hardware & Accessories
Noma 052-8870-6
OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
Dec 02, 2013 | Hardware & Accessories
Is the day of the week in the middle of dau or night or at the beginning it on the GE vacation timer?
Vacation timers turn lights on-and-off at random times.
Timer dial rotates clockwise. Notice small arrows on timer dial located below each day letter.
Each day starts at the letter.
When the time-now pointer is at W, then wednesday starts.
For example W is wednesday. And th is thursday. The hours that show between W and th are wednesday hours.
Open following image. The time now pointer is pointed at 4:00pm Wednesday.
The blue letters with white background are AM, and white letters with blue background are PM.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
To set current time, rotate dial clockwise until current time lines up with time-now pointer.
Time-now pointer is stationary.
Open following link to see how to set timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Add a comment for more free help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | GE 50462 7Day Random Vacation Timer
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Timer is only set to nearest hour.
FOR MANUAL OVERRIDE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to program my Woods N1506
FOR MANUAL OVERRIDE
Dec 13, 2010 | Woods Hardware & Accessories
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
FOR MANUAL OVERRIDE
Nov 23, 2010 | Woods Outdoor Lighting Timer
I cant get in at all I set my password as my daughters name but its not working
try various ways of typing it in, ie all CAPITALS, small case, Start with capital letter ect ect.
hope this helps.
Aug 15, 2010 | Computers & Internet
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Nov 20, 2008 | General Electric Stove/Oven/Range Chrome...
DeLonghi KH190920 Oil Filled Radiator Heater Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
