Question about Sportline 345 Electronic Pedometer
NO BATTERY PROTECTOR TO SLOWLY PULL
I am afraid to break/snap while I search for this battery protector. Should I remove the three screws on the back to access it?
  • Terry Casey
    Terry Casey Mar 26, 2014
    Me again, now I feel very stupid....I could not open to the back but my husband did and I now see the battery protector. Sorry to bother you.
Cannot remove lamp from mitsubishi HD1000
Hello
The proceedings to take out lamp are:
1. Reverse the projector gently.
2. Loosen the screw (a) using a Phillips screwdriver (+), and
remove the lamp cover (b).
3. Loosen the screws (c) using a Phillips screwdriver (+).
4. Pull up the handle.
5. Pull out the lamp box by the handle while holding the
projector.
• Pull the lamp box out of the projector slowly. If it is
pulled out quickly, the lamp may break scattering glass
fragments
It must come out easly. There are only three screws to seccure it in place.
Oct 29, 2011 | Office Equipment & Supplies
Is it possible to disassemble the BN59-00851A Remote? I see only one screw under the batteries, and removed that, but the cover will not come apart. There must be some sort of screw or snap still holding...
I actually opened it!!!!!! You will need something super thin yet strong to get the
faceplate off pry upwards where the tabs are. I used a small screwdriver and chewed up the sides. hope you have a better way. after it is off it is easy to disassemble the rest. When putting it back on make sure the battery terminals get into their slots and just snap back on. good luck!9_29_2011_2_09_04_am.jpg9_29_2011_2_09_18_am.jpg9_29_2011_2_09_27_am.jpg
Dec 22, 2010 | Samsung BN59-00851A Remote Control
Battery door replacement how to? The battery door on my Nikon Coolpix L5 doesn't stay closed anymore because a little piece broke off when I dropped the camera. I can get a new battery door cover but...
OK IT IS EASIER THAN IT APPEARS TO BE(DONT GET SCARED)#1 REMOVE BATTERIES AND MEMORY CARD AND STRAP(if you have one)#2REMOVE ALL THE SCREWS AROUND THE CAMERA(you will see 3 screws around the tri-pod mounting hole DONT REMOVE THE LONE SCREW THAT IS CLOSER TO THE LENS(AS IT IS NOT HOLDING ANYTHING BUT THE TRIPOD INSERT AND LEAVING IT IN WILL MAKE IT EASIER TO SNAP EVERYTYHING BACK TOGETHER.#3CARFULLY AND EVENLY PRY ON THE BODY TO REMOVE THE SCREEN SIDE.#4 NOW YOU WILL BE ABLE TO SEE THE SMALL CLIPS THAT HOLD THE LENS SIDE OF THE BODY CARFULLY SEPERATE FRONT BODY (* this will enable you to see the large head on the battery pin.) #5 WITH A THIN NEEDLE NOSE PLIERS PULL THE PIN OUT #6 LAY THE NEW COVER DOWN AS IF IT WAS CLOSED AND INSERT THE PIN BACK IN.#7 BEFORE YOU SNAP THE FRONT BOBY BACK IN BE SURE TO PUT THAT TINY RUBBER BATTERY PULL TAB BACK IN THEN CAREFULLY SNAP THE FRONT COVER INTO THE CHROME AND THEN THE BACK COVER. PUT SCREWS BACK AND YOUR DONE.
Jun 21, 2010 | Nikon COOLPIX L5 Digital Camera
Removing rear tail light in Lexus lx 470
Open the tailgate and then you must unsnap the carpeted part. It's easier with two people as the plastic part that says "Lexus" has to be pulled up out of the way as it will spring back in place if someone is not holding it. Don't be afraid to pull on the carpeted part; it will snap back with ease. When it's off you will see where the lights are. There are three screws you must undo so you can take off the metal cover. Should be pretty easy from there!
Sep 11, 2009 | 2004 Lexus Lx 470
HOW TO REPLACE HAZARD SWITCH IN 1997 CHEVY BLAZER. IT WILL NOT GO OFF
You have to unhook the battery then you have to remove the two screws that hold the horn on next remove the ring that has three screws in it and then remove the center nut pull the steering wheel with a steering wheel puller, you can rent it ad return it for your money back next use the U shaped clamp to compress the center plate down 1/4 of an inch then with two picks remove snap ring, next pull plate off, next unhook the wiring harness and pull the three screws out of the turn signal switch and pull switch out of column and replace with new switch.
Jul 18, 2009 | 1997 Chevrolet Blazer
43FWX20B. Convergence problem.
Look for hidden screws in the board... that's all I can say from experience. Plus, for the three red HV leads, Push down into the block and turn. This should release them if there is no other visible means of mechanical retention.
May 18, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Fellowes C120-CShredder Full but I can't pull the plastic bin out
Yeah, you can take the top off.... My C-220 had three screws under the front top area, and then two snap-out tabs at the top back area. It was easy.
May 07, 2009 | Fellowes Powershred 120C-2 Shredder
Disassembling the speakers - Compaq Jbl Pro (401508-001)
pry the speaker cover slowly using small screw driver on the side,,it has four locks giong thru..its position two at the top and two at the bottom..it is line w/ the volume control and headset..be careful not to break the speaker cover.then remove the four screws inside the hole where the speaker cover is position.remove also the rubber protector beneath the speaker or under the speaker..it has a lock beneath the rubber covering it..push the lock slowly, be careful not to break it.but even if you break it,it will do nothing..now insert finger in the hole and pull the face or pry w/ small screw driver and lift...
Apr 15, 2009 | HP Compaq JBL Pro (401508-001) Computer...
I need to replace a brake light on my 2003 Mitsubishi Outlander. We've removed the two obvious screws but are still facing resistance on the other side of the cover. Should I just pull the unit off? ...
sometimes they would be sideways. the screws just hold them in order not to move and they do have plastics hooks that still hold it tight to the metal housing. slowly slide them sideways and see if they would come off.
tnx 4 using fixya,
drcool
Oct 05, 2008 | 2003 Mitsubishi Outlander
Kodak EasyShare Z612 Digital Eye piece
you have to take off the back plastic part of the camera carefully. I snapped it off carefully. Then you take off 2 black screws at the eye piece and insert the rubber. screw back together. snap plastic back on and screw in all the screws. have fun!
Jan 09, 2008 | Kodak EasyShare Z612 Digital Camera
Sportline 345 Electronic Pedometer Logo
Top Sportline Sport & Outdoor - Others Experts
Raymond Richards
Raymond Richards
Are you a Sportline Sport and Outdoor - Other Expert? Answer questions, earn points and help others
