Question about Konica Minolta Bizhub 42 Copier
Blowing fuse i plug my konika minolta on 220V,and the fuse is blowing.after that i change the fuse with same value and rating,when i turn on my copier the fuse is keeps on blowing.what's the problem of my copier?
  • Konica Minolta Master
  • 1,297 Answers
Remove the fusing unit ,change the fuse on new and turn ON.If the copier worked the problem is in the fusing unit,the thermistor or thermofuse is in shortcircuit.
Posted on Mar 26, 2014
Nicolomd
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
  • 15 Answers
SOURCE: Code C0510 on our Konika Minolta Di 181
Check heater lamp or thermostat might burn out
Posted on Apr 16, 2009
firecontrol7
  • 6161 Answers
SOURCE: service call 05H
Flash ROM upgrade failure. Engine firmware upgrade failure. Attemp to re-upgrade. Check for proper firmware,
Posted on Aug 08, 2009
Bizhubman
  • 108 Answers
SOURCE: Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
Posted on May 12, 2010
Nicolomd
  • 84 Answers
SOURCE: konika minolta pagepro 1380 printer
try out the vista driver>it may be functional for win7
Posted on Jul 23, 2010
My konika minolta bizhub 162 is saying service call C0500 and then restarts what can i do
Verify the fusing unit components (heater lamp,thermistor) and the rear contact Switch located under rear cover when you closed the fusing unit right cover door.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
Jul 26, 2013 | Office Equipment & Supplies
I have problem with konika 1380 multifunction, error is service call 40.....pls give the soluton. Thanks Raj
Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit
value.
Apr 06, 2011 | Konica Minolta PagePro 1380 MF Laser...
My konika copier error code c9401. How to clear code.
Try this steps
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
1 Check the flat cable for proper connection and
correct or change as necessary.
2 Change PWB-C.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | Konica Minolta bizhub C250 All-In-One...
Service call 05H,for konika minolta magicolor 2490MF,konika minolta printer
Aug 07, 2009 | Konica Minolta Office Equipment & Supplies
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
Konica Minolta Bizhub 42 Copier Logo
46 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
