Question about Braun Syncro 7526 Electric Shaver
Where can I purchase the circuit board and batteries in Johannesburg
Replace circuit board and batteries 5720 razor
  • Braun Master
  • 1,610 Answers
Braun no longer supplies this type of replacement part for any of their shavers. Unfortunately, they are no longer available.
Posted on Mar 29, 2014
How do I remove the batteries from a Norelco 4605x razor ?
Remove the 4 screws on the back to take off the back cover. You will have to extend the trimmer to access 2 of the screws. You can then unsolder the batteries from the circuit board.
If you are replacing the batteries, for easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find replacement batteries for model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Jan 12, 2011 | Norelco Health & Beauty
Philishave8890 when the razor states fully
It sounds like the battery pack needs replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Sep 26, 2010 | Philips Health & Beauty
Razor wont charge
Yes, the batteries can be changed. You will find replacement batteries for model 6705X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change the batteries, you will need to remove the lotion cartridge cover on the back and then remove the screws on the back of the inner cover. Remove the back to get to the inside of the shaver. The batteries are soldered to the circuit board. You can unsolder them or it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs. Reassemble in reverse order
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Jun 10, 2010 | Norelco Advantage 6705 X Electric Shaver
Norelco razor 6867xl - am planning to replace battery pack. Would be easier to solder if I could remove the whole circuit board system from the hard plastic case. How do you release the metal clips?
The whole circuit board is removable, and I would recommend removing it from the whole external case to work on so nothing is damaged by your soldering iron.
Battery : 2x NiCd AA
Battery capacity : approx. 700 mAh
May 20, 2010 | Vacuums
I have a Braun 5525 rechargeable razor purchased in 1996. It no longer recharges, and in the charge window displays a jagged line rather than a battery image. Is this a problem with the internal cell, and...
In that case, the circuit board in also bad. This happens when the batteries aren't changed in a timely manner. You can buy a circuit board with batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
To open the shaver you will need to remove the two plastic screw covers on the bottom on either side of the port where the plug fits in. Then remove the screws underneath. The outer case will then slide off the bottom. You may need to reposition the travel lock to get it all the way of. Then unsnap the black plastic back of the inner case and remove it. You can then lift out the old circuit board. Reassemble in reverse order.
Feb 20, 2010 | Braun Health & Beauty
Battery is not holding charge as long as it used
Sure, the batteries can be replaced. Some soldering is required. If you are capable, you can do it yourself or you can have it professionally done. shaveroutlet.com offers the batteries or repair service. See links below
If you decide to have it professionally done, you can simply purchase the repair service from the website and follow the instructions for sending it in to the company.
If you do it yourself, you will need toremove the two screws on the back of the shaver to remove the back cover. You will the see the batteries andwhere they are connected to the circuit board.
You may find it easy to use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. You can use a small flat screwdriver or similar object to do this. This allows the old batteries to be removed but leaves their tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 23, 2010 | Norelco Spectra 8865 XL Electric Shaver
I own a Braun Electric Shaver Model 6525 Flex Ultra Speed. I plug it in and nothing! I am pretty sure the rechargeable battery needs replacing and I don't know how to open the razor to replace it. Also the...
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
Jan 15, 2010 | Braun Flex Integral 6525 Electric Shaver
Not accepting password. Unable to change or alter any password.
It is a small 25 cent sized battery that help the cmos hold its memory. You will find it on the mother board, the big main circuit board in the computer.
May 31, 2009 | Acer Aspire 5720 6497 Laptop
Shaver suddenly stopped working
I had the same problem with mine right after the two year warranty expired.
BUT I FIXED IT!!!
The problem seems to be bad engineering. Apparently the cleaning solution works its way into the circuit board of the shaver.
I took the razor apart (you need very small phillips screwdrivers), there are six screws. First remove the foils, then the blades (just pull them up). Two screws are where the head rotates. after removing the head, there are two more screws underneath the head. There are two more screws on the bottom under plastic caps beside the charging terminal. You can now gently slide the razor's hardware out of the case by pulling up on the head mounting arms while holding the case as you normally would shaving. (This sounds confusing but should be obvious as you do it.)
Looking at the circuit board i noticed some white residue on the board. I gently cleaned the board with small amount of alcohol and q-tips, being careful not to catch any cotton on the components of the board. At this point you can at least confirm that the motor is not burnt out and the batteries are charged by placing a flathead screwdriver between the positive terminal of the battery and the motor. It should come on if the motor and batteries are okay.
Next you hit the reset button at the bottom-front, then see if it comes on using the on/off button. You can do this step with the razor disassembled or assembled.
Hopefully this works for you. Now if only i could figure out a way to clean and refill the cartridges instead of paying $5 for 5 cents worth of cleaning fluid.
Feb 03, 2009 | Braun Flex XP II 5790 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
120 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
