Question about Miele H187MBALU Convection/Microwave Oven
Microwave not working
Not working with code F02 showing
Why is my samsung microwave showing -se-
It thinks it has a shorted membrane switch on the control panel. Unplug it for a minimum of 30 minutes to see if the code clears. If it doesn't, you might actually have a bad switch, and the touch pad might have to be replaced.
Aug 14, 2016 | Samsung Microwave Ovens
Maytag Microwave MMV4203DB00 HAS A 5E CODE AND IS NOT WORKING AT ALL WHAT CAN I DO?
Hai,you unplugg it for few seconds and reconnect if doesnt clear its a pc board problem which will need atechinician
Sep 12, 2014 | Microwave Ovens
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to http://www.searspartsdirect.com/ and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
Sep 11, 2014 | Kenmore Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Maytag Microwave mmv4203ds00 SE Error code
Not always is in the keypad the problem,in my work the problem was in one of the connectors in the control board.Resolder the contacts and it'll be fine.
Nov 22, 2011 | Microwave Ovens
My microwave is not working at all. It is showing a code that says E-5 or S-5, I can't tell. What is this?
Sorry to hear your having problems! Are you able to reach the plug, if so try unplugging it and plugging back in! This may reset your microwave? If not, here are a couple of website links you might try...
www.applianceaid.com/procedures.html
www.espares.coo.uk/advice/microwaves/a/2 This one shows Videos!
Or you can do a web- search typing in: Samsung Microwave 1.8 Cu Ft Codes
If you would like me to do the searches for you, I'll be happy too, just reply back.
Kind Regards!
Martie
Sep 15, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Miele H187MBALU Convection/Microwave Oven Logo
Top Miele Microwave Ovens Experts
William Miller
William Miller
k24674
Armin Buehlmann
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
