Question about Kyocera TASKalfa 180 Copier
Error J21 on taskalfa 180
After every copy prints J21 error appears
    Problem Solver:
  • 43 Answers
Try taking out the cassette and cleaning the pick up feed rollers with isopropyl alcohol. jam 21 is no paper pick up from cassette.
if this does not work my need new feed rollers or feed clutch
Posted on May 09, 2014
babaprithi
  • 372 Answers
SOURCE: Kyocera TASKalfa 180 a3 Grayscale Copier cartridge
toner catridge Rs 3600 or $75
Posted on Sep 17, 2011
SOURCE: Free service manual with code
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Posted on Aug 24, 2011
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
  • 523 Answers
SOURCE: printer driver for taskalfa 180 which works in
Go to www.copystar.com
look under black and white multifunctions, then choose your model.
after that select under the sub category print drivers.
It will gives you all the drivers for windows,mac,unix.
Note Copystar and kyocera same machines and same drivers.
Posted on Nov 12, 2011
Kyocera TASKalfa 180 Grayscale Copier J21 error
clean or replace the rollers for the cassette or check behind the cassette for paper
Jan 12, 2017 | Kyocera Office Equipment & Supplies
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
Oct 28, 2015 | Office Equipment & Supplies
How do i fix the error c-6000?
from key pad press 1087 1087, the copier will go to maintenance mode ,press 163 then print key , press execute ,you may have to turn copier off the on again, if copier resets it good to go,
if not it will need a new fuser assy.
Jun 16, 2015 | Kyocera Kyo1t02kh0us0 Br Taskalfa 180...
I have a kyocera 180 copier does not print texts even when we do internal print. it's blank when copying. We change DRUM, TONNER, DEVELOPER and MOTHER BOARD but still the same. Is there any other thing...
I have a kyocera 181 copier when we switch on the machine it showing error message " shake the toner container' kindly do the needful or send me service manual as soon as possible
I am awaiting for valuable response....
Sep 18, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
How do i solve error c3100 in brand new TASKalfa 180
You need to update the machine firmware, it will takecare of this Error.
Nov 08, 2011 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
To reset -
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Kyocera TASKalfa 180 Copier Logo
602 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
