Question about Mitac Magellan Roadmate 2136t-lm Automobile Portable Gps Navigator - 4.3" -
Route error message - Mitac Magellan Roadmate 2136t-lm Automobile Portable Gps Navigator - 4.3" -
HOW I FIX THE MESSAGE I GET WHEN I HIT NAVIGATE - ROUTE CALCULATION FAILED
Doy you get that message always, or only when you are inside a building or close to very tall buildings?
Make sure your device has a clear view to open sky, so it can find enough satellites, to calculate where it is. And if this happens, give the device enough time to find out. It could take up to one or 2 minutes before it is ready.
Jun 03, 2014 | Navigon 2100 Max Portable GPS System
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
The message "50.2 Fuser Error" has appeared in the window. Despite checking all the paper routes and finding nothing the message will not go away and the printer will not work.
That fuser error says that either the overtemp fuse is burned out, or the lamp is burned out, you most likely need a new fuser for the error to go away.
Dec 22, 2009 | HP LaserJet 2840 Printer
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
  2. Select myMaps
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Route 66 Mobile 8 Windows Mobile - software update creates error
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Dec 27, 2008 | Route 66 ROUTE EUROPE 2004 (601184407502)...
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Mitac Magellan Roadmate 2136t-lm Automobile Portable Gps Navigator - 4.3" - Logo
Top Mitac GPS Experts
Ed Mac
Greg Cann
Greg Cann
Are you a Mitac GPS Expert? Answer questions, earn points and help others
