Need plug wiring diagram to ZUNE 120 Gb
I'm connecting my ZUNE player to my Ford stock radio with a iSimple interface that gives me a 3.5 mm plug to connect to my headphone jack. But I also need a separate ZUNE cable to recharge battery from the bottom with a cigarette lighter adaptor. Would like to only have 1 ZUNE cable plug, not 2 plugs to deal with. Would like to modify the stock ZUNE cable to get the audio outputs I need to send down the 3.5 mm line to radio. Can anyone tell me if there is a cable already OR can you give me the ZUNE plug wiring diagram so I can tap into the harness to get the headphone outputs to make my own harness. Also, do you know if these plug outputs are the same volyage that the headphone jack is ? THANK YOU ALL.
  • 3,320 Answers
Here's the pinouts. The Zune Pinouts Zune Boards
Posted on Mar 26, 2014
Admiral James Lyons is he telling the truth on the infiltration of the national security?
Your question has nothing to do with Interface Isimple Isgm571 Gm Ipod Aux Factory Radio Interface. Now, my personal opinion is that Admiral James Lyons is right and USA National Security program has benn compromised, but that's just MY opinion.
Feb 21, 2015 | Interface Isimple Isgm571 Gm Ipod Aux...
Zune 120 gb. contact support.?????
Try holding up and back at the same time until the zune resets. Mine has had that same problem, and I end up resetting it a few times and eventually it works. You will then have to connect it to a computer to reload the firmware and your media.
Jul 05, 2011 | Microsoft Zune JS8-00001 Digital Media...
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
Installing newer radio in older truck
the easiest thing you can do that will give you step by step directions. Go to http://www.crutchfield.com/ or call 1-800-319-8264 and tell them what car and what radio you have. They will sell you a adaptor and face plate with step by step directions. Everything you absolutely need.
tepfy
Jun 10, 2009 | 1990 Ford F150
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Jan 18, 2009 | Motorola Talkabout T5420 (14 Channels)...
Installing aftermarket radio in 2004 ford focus
the 3rd plug is for volume etc on the sering wheel
Jan 09, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
'98 Grand Cherokee Factory Radio - Zune Interface?
There are adapters that you can get to connect the speaker wires to in order to get the aux jack levels the Zune needs. Amazon com Speaker RCA Line Level Converter Adaptor High Low Hi Lo with...
Sep 04, 2017 | Jeep AM/FM Cassette with CD Changer...
Need the audio wiring diagram to connect premium cd player
i need to know if my 2002 ford ranger standard cab truck has a cd connection on the stock radio
Aug 02, 2008 | 2002 Ford Ranger Regular Cab
107 people viewed this question
 Grubhead
Grubhead
