Question about Omron Health & Beauty
Not working when on button is pushed machine starts taking pressure
Looking for how to lower the pressure foot on model 16782
Are you talking about presser foot pressure--the amount of pressure the presser foot applies to the fabric and feed dogs?
Some machines have a dial that can raise or lower the pressure.
Some machines have a screw located at the top of the presser foot bar that can be tightened or loosened. (Unfortunately, manufacturers usually did not include this information in the user's manual.)
Even older machines sometimes have a spring-loaded push-button on the top left of the machine. When pushed in, it collapses the spring that applies less or more pressure to the presser foot. The inner button actually applies the pressure in "degrees" which is regulated by how far the button is pushed in. To release this pressure button, press on the outside ring to release the spring. (Incidentally, it is a good practice to release this spring when you are finished sewing. Storing it with the spring compressed may eventually cause the spring to lose its effectiveness.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
Parts of Sewing Machine Pressure Adjustment
http://makeitsew.biz/presser-foot-pressure
Sewing Machine Pressure Settings for Machine Quilting
Nov 27, 2016 | Sewing Machines
I have error C7 on singer one plus and it wont sew at all?
I was getting a C7 error on my Singer Heritage sewing machine every time I pushed the pressure foot. I decided to see if the reverse sewing button would work and it did. Then I pushed the pressure foot to sew again and it worked. Hope this helps someone else.
Jan 27, 2013 | Singer Sewing Machines
Will not start
There can be a battery problem. Omron products are very accurate in their work. You should replace the battery and check again.
Jun 01, 2012 | Omron Healthcare Omron Hem 711DLX...
PUT IN TIME/DATE ON CVS MODEL KD556 SKU 800231 BLOOD PRESSURE MONITOR, THERE R 2 BUTTONS, START & MEMORY : NO SET BUTTON
On your model, hold the "start" and "memory" buttons at the same time. After about 3 seconds the month will start flashing in the window. Push the "memory" button until it gets to the month you want. Then hit the "start" button and the day of the month will flash. Push the "memory" button until the correct day of the month comes up. Push the "start" button again, and the hours will flash. Push the "memory" button until the correct hour comes up. Do the same for minutes, and the next time you push "start" it goes into ready mode.
Apr 07, 2012 | Health & Beauty
Our F&P DD601V2 double dishdraw is showing error 'U3' and the water does not totally drain out after a cycle, any ideas? Thanks
This applies to all DD601 and DD603 dishdrawers.
U3 is either one of the following:
- Drain pump is blocked.
- Drain hose is blocked.
- Sprayarm or rotor not turning freely.
- Motor electronics have failed.
- Machine set to 'LP' on a high pressure water supply.
Often it's just the last one, "Machine set to 'LP' on a high pressure water supply.", as this can be unintentionally changed by a user from an uncommon course of events. Sometimes, due to the technical design of the way the buttons work, if water bridges the 2 "Programme" and "Eco" buttons (inside on the top right of the tub), pressing either one, or both, (or just having your finger in the water) for longer than 5 seconds brings up a special mode that a user, in their ignorant attempts to get out of it, can erroneously change the pressure setting, subsequently causing a U3 error. It happened to me once when I was cleaning the machine, wiping around the Programme buttons.
To change to the proper High or Low Pressure settings:
1) LCD Display on. Hold the Programme and Eco touch switches simultaneously for 5 seconds.
2) Machine beeps and "HP" or "LP" is displayed in the LCD.
3) Push the Start/Pause button to toggle between them.
4) Push the Power button when correct selection complete.
Apr 07, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Lg washing machine wf-t655th won't start
Auto/off is power button--correct?
start/pause button actually starts the unit--correct?
Jul 27, 2017 | LG Washing Machines
Red light comes on when pressure foot is down
Is your bobin winder thing on top pushed to the left? If it is pushed to the right - the machine will not allow you to start sewing.
Jan 04, 2009 | Singer 5050 Mechanical Sewing Machine
Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Oct 16, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Dryer with problem
when it dont work open the doorthere a switch that when you close the door machine start leave the door open and take a pen and push the swicth in and try to start the machine if it work look maybe what apply pressure on the switch is bend or not long enough take care cheers
Jan 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Health & Beauty Logo
27 people viewed this question
Top Omron Health & Beauty Experts
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
