Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Intermatic pool timer
My pool timer will turn off but I have to switch it on by hand. Any suggestions?
    President:
  • 1,723 Answers
You need to have a 'tripper' for 'on' time and a tripper for 'off' time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Grasslin Intermatic pool timer turns on and off randomly
did you change the base out or just the clock?? it could be shorting out threw the base
May 29, 2014 | Intermatic Grasslin Pool Time Clock 24hr...
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 15, 2013 | Pool & Spa
Manuals for pool timers
1) Copy following links for Intermatic pool timer manuals and wiring:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
2) Add a comment and describe timer in detail for possible additional resources
Feb 05, 2013 | Intermatic T104R DPST 24 Hour Mechanical...
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
Need trippers for older unknown model number amf paragon pool timer. timer is 15 - 20 years old
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Jul 21, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Intermatic pool timer E10694 does not turn on. It shuts off okay.
Open following link for troubleshooting checklist:
If dial is rotating, then tripper might need to be replaced.
The problem here is I cannot identify E106 timer
Intermatic product Index, and pool and spa catalog do not show that specific model among digital or mechanical timers.
Maybe you have T106 2-speed pump motor?
Add a comment with in-focus photo of timer you posted on Flickr for possible identification.
Upvote the help.
May 17, 2011 | Intermatic T104 24h 208-277v Mechanical...
Pool pump cannot be turned off with timer switch. Pump runs constantly. I can turn off with breaker switch but not with switch on timer.
You posted under Intermatic EI200 series countdown timer.
Intermatic EI200 series is rated for 1/4 HP.
Check nameplate on motor for HP. Pool pump is probably 1 HP.
Open following link for countdown timer ratings:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Add a comment and say what kind of timer you are using and say specifically what you want timer to do, and I will locate correct timer for that specific need.
You can also add a contactor to the circuit.
Timer controls contactor, and contactor turns pump on-off.
http://waterheatertimer.org/Water-heater-contactors.html
Also take advantage of fixya expert assistance live.
Apr 04, 2011 | Intermatic EI220 Electronic Auto Shutoff...
Intermatic Pool timer will not turn off... I have to shut off the pool pump at the breaker... Any suggestions on what the problem might be?
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
Jan 18, 2010 | Intermatic Timer T12404R Pool & Spa...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
296 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
