Question about Velodyne DLS-3500R Speaker
Velodyne dls3500 hum
Hum
Velodyne CT-100 when switched on connected to nothing else makes a very loud humming sound & the speaker is pushed outwards
Replace all the greatest sized capacitors inside are deformed or leaking. can be a 6 pieces because some of them are used parrallell to get double capacity.
May 22, 2016 | Velodyne Audio Players & Recorders
Velodyne ct100 loud humming +speaker drown backwards.Can I fix at home
The loud humming could be caused by a cable on the input that is not grounded. It could also be caused by some sort of power supply failure.
Feb 10, 2016 | Velodyne Audio Players & Recorders
Velodyne dps 10 rca hums but wired is fine
The issue a floating ground that causes the hum you are talking about. What are you connecting it to that causes the hum?
Jan 07, 2014 | Velodyne DPS-10 Subwoofer
My Velodyne DPS-10 subwoofer hums when you plug in the RCA cable. The hum increases in volume when you touch the rear metal panel.
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
Jul 17, 2011 | Velodyne DPS-10 Subwoofer
I have a Velodyne fsx-12 subwoofer. Problem is
Velodyne is the only source for parts and service on this unit.
You will need to contact Velodyne
Sep 18, 2009 | Velodyne FSX-12 Speaker
Speaker would push out and stay out with a hum when turned on.
Sounds like the "servo" on this unit has gone bad.
You will need to contact Velodyne for service on this.
It is the only place to get parts and service for this unit.
Apr 01, 2009 | Velodyne SPL-1000 Subwoofer
Velodyne F-1800 RII Subwoofer Fuse
I am having the same problem... call Velodyne... if you have the coke can thing with the pink stuff it can't be repaired.
Dec 30, 2008 | Audio Players & Recorders
Velodyne DLS-3500R Speaker Logo
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
