Question about Welding Tools
How to hook up my co2 bottle to my welder
Not Shute I have all my hose fittings to hook it up
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: clarke 135 -gas/no gas- mig
Any welding supply or a welder with bottle exchange should carry all the gauges and gas you need. There has to be one near you. We live in a cow town here and we have a bunch of them. Check it out, hope this helps.
Posted on Dec 20, 2010
Soda stream
fit a new gas bulb as they are only good for a couple of bottles
Jan 11, 2016 | Home
Where can I purchase the small clear gas hose from argon bottle to welder
Any welding equipment retailer should sell the gas hoses.
May 29, 2014 | Solar Welding Tools
Clarke 135 -gas/no gas- mig wire welder ...needing the argon/co2 gas bottle regulator that fits that model... dont know where to buy in kcmo area or who to order from...THX Larry Laing
Dec 20, 2010 | Garden
What gas do i use for welding mild steel .I have argon and co 2 canisters
Can use argon/co2 mix or CO2 the wire usually has the gas named on the lable
Aug 26, 2010 | Clarke Power Products Clarke 130EN...
Ac problem
the refill bottle shouuld never be attached to the high pressure side (high side) .. the connections are different to prevent that .. if you did manage to hook that up, there would be great danger of the bottle exploding ... so you can only hook the bottle up to the low pressure side (large piple) ... the retrofit kit should have included adapters for both high and low pressure sides ... the correct adaptor should fit the R134a refill bottle hose ... it should also fit the low pressure port (you may have to remove the valve in the old port (read instructions for that) .. if the adapter does not fit then you might check with a dealer or air conditioner supply house for a special adapter ... R134a and R12 are completely incompatable so make sure you have washed out the system and replaced the dryer and sometimes the hoses ... you cant have any of the old lube left in the system .. its generally a good idea to replace all rubber parts for the changeover .. you will need to pull a vacuum for a couple of hours before refilling .. .
Jun 30, 2010 | 1990 Ford Bronco
What is the correct gas for miller renegade 180 weder generator mig
Depends on the application and type of wire you are using. If you are using flux cored wire you want Co2. If you are using mig wire 75/25 blend (Argon/Co2) would be my choice. Your wire should also give you a recommendation of which type to use.
May 07, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Ive never filled my own gas bottle Co2 do you screw the filling station straight onto the carbon dioxide gas bottle or do you run it through a regulator ?if so at what pressure do you set regulator at
You just need to. Hook your fill station up to the big co2 tank and then hook your little tank to the fill station and turn the little one on first then the big one and make sure the little one is completely empty before filling. Co2 is measured by weight not pressure you will also need to weight before and while filling to make sure you do not overfill. if its a 20 oz weigh it before filling it then zero your scale and fill until it reaches 20oz on your scale.
Dec 03, 2009 | Tippmann A 5 Standard Paintball Gun
Convert flux to mig
need to buy a gauge set up , these usually come with the hose and gauge,just attach in the back and hook up your bottle..
Mar 16, 2009 | Welding Tools
Welder work OK with flux wire, cannot get penatration in MIG mode
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
Mar 10, 2009 | Campbell Hausfeld WG2060 Mig/Flux Versa -...
Expansion tank lower hose...
make it fit ,change it for a longer one as long as it fits ,the one from top of the rad runs into the expansion bottle
Aug 07, 2008 | 2001 Volkswagen Beetle
Welding Tools Logo
24 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
