Question about Canon PIXMA iP100v + lithium battery InkJet Photo Printer
How to disassemble the chasis
We dont know the lock pin of chasis
Dell laptop not turning on
Check all the USB ports to see if they are damaged. If any of the pins in the USB ports are touching the chasis then this will case a short circuit and stop it turning on. With the power disconnected, move the pins away from the chasis using a small ascrew driver and make suer they are not touching each other.
Jul 30, 2013 | Dell Computers & Internet
CHASIS NUMBER JMFMNCJ2AKJ
Chasis ???dont you mean chassis number --- well forget the one in the windscreen thats not acceptable for the annual inspection ...top of bulkhead/sorry firewall ,rear chassis frame behind the wheel ,front chassis behind the wheel ,in the boot /trunk ,but some american cars actually put them under the carpet behind the brake pedal.sorry i dont know where exactly we dont have these cars in spain
Sep 11, 2012 | Mitsubishi Mirage Cars & Trucks
Hi I have got a new galaxy s and I have put in some pin code that i forgot. Now the phone is locked and doesnt allow me to do anything. I tried holding the volume key method but did not work. Similarly I...
Since it is new contact the vendor or dealer where you buy that Samsung smartphone, doing something like modifying operating system program, disassembling the unit, etc. will gonna void the warranty.
Best advice call their service hotline indicated in the operating manual. This will end your problem.
Jun 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
I do have a ASUS P5GC-MX/1333 REV. 3.05G Motherboard. Whenever I boot my computer it displays "Chasis Intruded" or "CMOS settings"..............and computer won't boot. after this when...
there are two jumpers side by side. one has 3 pins with same distance between them (for cmos)
and
the other one that has also 3 pings but 1 of them a little bit far from the other 2 (Chasis Intruded)
For cmos,
pin 1 pin2 conected is normal operation
pin 2 pin3 conected is for resetting the bios
if reset caried on jumper must be taken back to normal operation positing
Chasis Intruded worning is shown when chasis jumper removed or put on the pin1 so the jumper can not contact the pin2 and pin3.
You must connect pin2 and pin3 by a jumper and restart your computer. That is al.
Oct 26, 2010 | ASUS Computers & Internet
I want to disable the sim lock for my e250 bt i dont know the code or can i say the password
i am forget the sim lock.so, i want to disable the sim lock code.Please put up the pin
Nov 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
My phone is locked and I need a pin to unlock it, i dont want to call customer service, it locked out by its self where can i get the pin to unlock?
HI,
By default the pin may be 1234 or 0000, if you give PIN wrongly for 3 times , it asks for PUK, there is no other way of getting PUK other than through your operator...But operator dont know your PIN, They can tell only the default PIN....
ENJOY! RATE THIS SOLUTOIN
RNJ VINOD KUMAR
Jul 16, 2009 | Cell Phones
Chasis #
chasis ???dont you mean chassis number --- well forget the one in the windscreen thats not acceptable for the annual inspection ...top of bulkhead/sorry firewall ,rear chassis frame behind the wheel ,front chassis behind the wheel ,in the boot /trunk ,but some american cars actually put them under the carpet behind the brake pedal.sorry i dont know where exactly we dont have these cars in spain
Nov 22, 2008 | 2005 Chevrolet Silverado
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Error 511
It means the 3 pins for that fan are not working on motherboard . I suggest you use the motherboard 3 pins for the chasis fan and buy a CPU fan with 4 pin setting that connects to your power supply ( much better current )
Jul 11, 2008 | Compaq (283983-001) Motherboard
Hp m7580n mobo asus a8m2n-la was hit by lighting at ethernet input
Depends on what CPU you have stuck in it. Any micro atx AM2 mb will work as long as you know what power rating the cpu is 65w,85w95w. With HP and the rest of the crappy inti-graded mb using companies they like to use there own board connector which will not work with an after market. All you need is an old chasis tower pull the single pins off the wires and place them on the HP chasis wires getting rid of the 6 in 1 connector pin they use. After that you can use any after market like mother board in that tower.
Nov 21, 2007 | HP (D7580-60003) Motherboard
Canon PIXMA iP100v + lithium battery InkJet Photo Printer Logo
18 people viewed this question
old marine
old marine
