Question about Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 -
The tv is on but wont turn off
The TV froze on the start up and no buttons work
Direct Tv mini caused my Insignia tv to freeze and now tv wont turn back on
The direct mini did not freeze the tv. It's a coincidence. Your TV needs repair. Unfortunately insignia tvs have a reputation for problems like this.
Aug 13, 2016 | Insignia Televison & Video
The tv froze up while watching netflix and won't turn off or do anything
Sounds like the CPU froze. Unplug set from power completely, then plug back in, should work. If not then the problem will have to be solved by a repair technician.
Mar 12, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
My haier tv stayed in USB mode and just froze there off and on probe responds to the control and nothing. prove with the buttons on tv and neither worked
press on you remote repeatedly the keay "back", the screen will turn blue, then press "input" and select your option, it should work.
Mar 07, 2014 | Haier HL32D2 32 in LCD TV
TV NOT Turning ON
The repaired power board may have failed.
Jan 11, 2014 | Televison & Video
52" RCA Scenum froze and would not turn off. I unplugged it and then plugged it back in. All the lights are on in the front of the tv but it will not turn on.
The small signal board is the most likliest cause of that issue which is a very famous symptom for the ITC222 and ITC222A chassis RCA models. You can usually get the small signal board from www.tvrepairworld.com several versions were used so they can assist with identifying which version ssb your model requires.
Apr 03, 2013 | RCA D52W19 52" Rear Projection Television
Wii froze and wont Turn off after playing game
dead disc? or disc reader? also why woulf turning the tv off help? did the wii overheat? or anything strange?
Apr 05, 2010 | Nintendo Wii Console
Mitsubishi VS-45609 TV While having problem with convergence on my TV, I tried to adjust the settings. As I was messing with the buttons the TV froze and no buttons would work. I unplugged it to turn it...
I am at the same state your in the tv from back side of it inside holds 3 little glass fuses did you check those? for fuse pop i did mines still good
but still wont power back on just a quick blink from front when the power is plugged back in
Feb 20, 2009 | Mitsubishi VS-45609 TV
My tv wont turn on now
sounds like you fried your digital board or power supply not sure need more info on what tv is doing
Dec 30, 2008 | Samsung SPN4235 42 in. Plasma HDTV
TV WONT COME ON
I had the same problem. Take the back off the TV.....disconnect power supply first....
You probably will find a cooling fan on the right side that is froze up. Get a Strong vacuum, clean it until it turns freely. The TV will now work unless you have other problems.
Dec 06, 2008 | Philips 37MF321D 37 in. LCD Television
Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 - Logo
13 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
