Question about McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
Capacitor doesn't work
No power
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Sanyo EM-SL40S microwave everything seems to be working fine but food doesn't get hot?
see this causes and fix it. GOD BLESS YOU
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Oct 01, 2012 | Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
Trying to find out how to figure out why my fan motor doesn't work. If its grounded or a different kind of short
hi,
There will be two reason for the fan motor won't work. first of all replace the fan capcitor. In normal Ac fans there will be two windings. The starting winding and the running winding. Running winding will be driectly connected to the power trough relay switching circuit and the starting winding trough a capacitor. If the capacitor is faulty then the fan will not sart. There will be three wires from the fan, one will be common , second will goto power line and the third will go to one end of the capacitor.The other end of the capacitor will goto the power line. In some motors there will be four line. In such motors the fourth wire will be Ground (Earth) connection.
second reson will be the winding of the motor may burned. In such cases you have to replace the fan motor.
ok
Jul 31, 2011 | GE Heating & Cooling
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
Compressor works but fan doesn't ,the fan does work on on the furance
The outdoor fan is called the condenser fan, the first things to check are to see that its getting power and the capacitor
Jul 05, 2011 | Carrier 38CKC042 Air Conditioner
Purchased Vistaquest FS-503 converter. Used two days. Screen doesn't light up and closing cover doesn't turn off the power (light continues showing through the slot for slide holder). Any easy...
take it back for exchange or a refund. A capacitor in the circuit is at fault not distributing the needed power to operate this camera
Jun 26, 2011 | VistaQuest Cameras
HI I have a 30k BTU armstrong unit, compressor runs fine , but condenser fan doesn's start, does it works with the capacitor?
Many outside AC units have just one capacitor that starts the compressor and the fan. Some units however have two. Just follow the wires from the motor to the capacitor, pull it and test it. Make sure you disconnect the power from the unit by pulling the fuse block first. If the capacitor is good the motor may have siezed up or burned out.
Dec 17, 2008 | Goodman CKL36AR36 Air Conditioner
McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator Logo
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
