You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation
http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil
[email protected]
