Question about Hunter Dryers
Model number 23530-300
Fan will not work but the light will
I have an Alaska ceiling fan, Model AC4 42, Number 245460. Not sure that it is correctly wired - light won't work unless fan is operating. Are there any wiring diagrams available for this model?
Do you have a fan control on the wall? If you do and your fan & light have pull chains, Take the switch out & put in an on/off switch.
Oct 04, 2013 | Dryers
Wiring diagram 3 speed ceiling fan
Call 1-888-227-2178 with model & serial numbers of fan. Should be on top of motor housing.
Jun 11, 2013 | Dryers
Casablanca Intellitouch Fan was working fine.. Then only the light worked and fan switch made a quick bleep and started the blades moving but then both light went off and fan stopped. Now nothing works and...
Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
May 15, 2010 | Casablanca Fan 3245T Ceiling
Broan ventilation fan not working
Does it start before the mark as you turn it if so replace the switch. power off first and check with a meter.
Jan 28, 2010 | Broan-NuTone NuTone Ultra Silent...
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Dec 03, 2008 | Aloha Housewares (93645) Ceiling Fan
Dryers Logo
14 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
