Question about Fellowes Jupiter 125 Laminator 5215801
Jupiter 125 laminator wont heat up
Laminator wont heat up
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Fellowes Jupiter 125 Laminator will not turn on. I've plugged it in, flipped the switch in the back, pressed the standby button to turn it on, just beeps at me. No other lights come on.
other than to ask did you take it out of standby and wait the 4-8 minutes for it too warm up ? I do have this phone number 4 u to call for help with this ,its out of back of my book ----b9gs27mjwtojdrmwfiqzolwb7uddvtk0jdb1qmk8qbuwdvylpkv71k2poierczcxrtrww73wvjcc7bk7jwoa6nmprqepzu9eoraynmuf+jerezcll0dvq0v1hqta91udnuvttmpvxzuspacoqsztxzvu4zeivsawqa+deugdqgcia0bgianayigdqgcia0bgianayigdqgcia0bgianayigdqgcia0bgiaple339yfgz6xceiraaaaaelftksuqmcc
Aug 18, 2016 | Video Game Consoles & Games
Need a gear box for a Fellowes Voyager 125 laminator
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Apr 29, 2015 | Fellowes Voyager 125 Laminator
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
Beeping and not turning on
This is the second laminator of the same model that is beeping and not turning on. What do we need to do to get this machine operational?
Dec 18, 2013 | Fellowes Jupiter 125 Laminator 5215801
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
A laminating sheet is stuck inside machine. You can't see it from either end and machine smokes when turned on now. It is a Fellowes EXL 125-2.
OOOOooooooooohhh!!!!!
Hate to tell you, BUT, the laminate is melted on the fuser. You learned the hard way, htere are specific laminates for different types of machines, the reason is because of the amount of heat it can tolerate. If you look in the back of the box it will tell you what machines they are good for, if yours is not listed, you should look at the manual or the website.
You will have to take it apart and remove the melted plastic, with hopefully minimal damage to your machine, otherwise the fuser will need to be replaced.
Sep 05, 2008 | Office Equipment & Supplies
Fellowes Jupiter 125 Laminator 5215801 Logo
130 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
