Question about Dryers
Drying time is too long
I have done all the recommended solutions for long dryer time, clean vent, check flow, had a service tech in to check thermistor- resistance OK, but the exhaust from the vent is no more than 125 degrees(manual says it should be 155 at max timed dry) Tech says the dryer is fine, however it still takes over two hours to dry a larger load. Dryer is 1 yr old and had this from the start. Wife is driving me crazy. It is propane & all is cycling fine.
Dryer is a Kenmore Elite Smartheat QuietPak 9 Frontload
    Sergeant:
  • 222 Answers
Suspect lint accumulation around one of the control thermostats or a partially blocked airflow path. For some reason, the thermostats 'think' the dryer is up to heat when it's not and are turning off the burner prematurely.
Could also be defective thermostats, although these are usually either stuck open or stuck closed when they go bad. I guess they could lose their calibration and open prematurely, but I think it's more likely lint accumulation somewhere.
Posted on Jun 15, 2009
May tag Neptune dryer forming moisture inside tub
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
Oct 10, 2014 | Dryers
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
The dryer is not drying as good as it should be and it will display the following letters AF
Hi and welcome to FixYa, I am Kelly
Your AF error code is most likely an "Air-Flow error. Long drying times are ALWAYS cvaused by poor air-flow in a dryer.
Since you did not include a "Make and Model number" this reponse is generic.
The causes are many.
1. Go outside and check the thru the wall dryer duct flapper. Make sure it is free of lint.
2. Pull the lint filter and wash it with vinegar. The water then soap and water with a very good fresh water rinse.
3. Inspect the area where the lint filter is installed for any signs of lint build up. Use a crevice tool and a stretched out and folded in half wire coat hanger (Looped) to reach deep onto the lint build up areas so you can remove the lint with a crevice tool and Vacuum.
4. Remove the vent duct from the back of the dryer and check the air-flow. The air-flow should push a relaxed hand / wrist gently away from the dryer vent hole with the dryer on. If you do not get this kind of aor flow you will need to ensure all of the lint has been removed from the internal dryer ducting. If your sure the ducting is clear and you stil have poor air-flow then most likely the blower wheel has failed, Most of the time the center hub will crack and the blower wheel will not turn at full speed. Other times a fan blade breaks and blocks the ducting.
5. Use a flash light and look into the vent duct hole on the back of the dryer. Check for a restricted duct. Clean as necessary.
The above are the most common reasons for higher electric bills and long drying times.
Have a 2nd person look for lint after your done cleaning! The more eyes the better.
Thanks for choosing FixYa,
Kelly
Jan 26, 2011 | Dryers
When I put the dryer on it smells as if something is burning. There is nothing in the dryer that would seem to cause this.
HI. You will need to make sure the dryer vent hose, as well as, the rest of the vent duct, is not clogged or obstructed. Unless regular maintenance is performed; chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified service tech perform this task. I am certain that your unit will need to be cleaned. The main target areas will be the blower housing and vent ducts.
Jul 01, 2010 | Miele Novotronic T1570C Electric Dryer
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
LG Gas Dryer (Model # DLG5988W) is not heating, the gas is not turning on. When the dryer is turned on the ''Check Filter'' light comes on and when switching to a drying cycle the ?Cool? light is always...
The dryer has a resettable SAFETY thermostat located on the flame tube inside the dryer. LG recommends replacing the Safety and High limit thermostats if the Safety thermostat is tripped. The dryer Glow bar igniter could be bad as well as the gas valve or Main computer. Time to have the dryer serviced by a qualified LG tech. LG has factory service tech in most large cities. Give them a call at 1 800 243-0000.
Hope this helps.
Mike
Oct 31, 2017 | LG Dryers
Does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
For Gas Dryer, Check the following---
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
Jun 01, 2009 | Maytag Dryers
Kenmore elite HE 4 IS NOT DRYING AND GIVING BURING SMELL
ensure the lint screen is clean, check your discharge vent hose for blockage or kinks. You may need to move the dryer out from the wall to thoroughly inspect the vent hose. while the vent hose is removed from the dryer, start the dryer momentarily to ensure the is sufficient air flow exiting the unit.
Feb 08, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer is acting up
Sounds like you've done everything except check for air flow? When you run it, do you get ANY air flow thru the vent? If not , then your blower is either defective, not working or clogged.. Hope that helps..
Aug 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
Marvin
Marvin
