How to replace motor on 42 in county line barrel fan
Need diagram of the 42in county line motor for barrel fan to check the assembly. the bolts don't seem to be long enough for bolts to secure motor to frame. used original bolts
yalmer
  • 549 Answers
SOURCE: need replacement motor
Before trying top replace anything, make sure you have power at the motor from the cord.
If you have no way to check for power, unplug and change the cord to any other you have around.
That will assure that the cord is good or bad.
Posted on Feb 16, 2008
  • 113 Answers
SOURCE: Underbody Spare Tire Cable Assembly
best place would be in a junk yard
Posted on Jun 26, 2008
  • 96 Answers
SOURCE: heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Posted on Dec 10, 2008
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
  • 148 Answers
SOURCE: AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Posted on Jun 21, 2009
Manual for 24 hp 42 craftsman - Diagram and How to change the drive belt?
Remember this,there is a belt diagram under the left foot rest. It will show you how the belt is rigged onto the pulleys. In changing this belt you will have to pull the clutch assembly,from beneath the motor. Only one bolt holds this assembly to the motor's vertical shaft.Once removed,install the belt onto the pulleys. Then slip the belt onto the clutch assembly's pulley and lift straight up,align the key way with the key and slip on the clutch assembly and replace the bolt.Torque down the bolt,i can't remember the torque pounds,but i believe it's 100-200 lbs. of torque.B. Locke
Sep 28, 2015 | Craftsman Garden
How to replace an indoor fan motor on an Airwell air conditioner?
There will be a set screw on the shaft accessible either through the end of the blower wheel opposite the motor or through a notch in one fan blade that lines up perfectly with the set screw. If there is a notch in the blower wheel, it will take a long allen wrench to reach the distance to the wheel hub. But you can use a short angle type when you have the assembly removed and sitting on the floor. The other type usually has a 5/16" square headed set screw securing it to the shaft.
Check for rust on the shaft and if it is covered, sand it shiny with sandpaper prior to attempting to slide the motor out of the squirrel cage hub. A little WD-40 really helps.
Dec 23, 2014 | Heating & Cooling
Husqvarna 42" Yard Tractor YTH1542XP rear fuel line leak
Been looking the parts diagram, it shows 1 line on the tank. Need to replace line.
Nov 24, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Manual for wearever super shooter cookie press
Instructions hand copied from my old manual
1. Stand motor on flat surface; screw barrel securely into place.
2. Attach flat side of piston onto screw and turn far enough to see 1-2 threads
3. Insert assembled piston/screw in barrel so that notches in piston line up with the ribs in barrel; snap screw into place.
4. Fill barrel with desired mixture, using small amounts at a time and tamping into place with barrel loader; wipe any excess mixture from exterior of barrel
5. Select desired cookie disc or tip; place on filled barrel
6. Attach cap to barrel; tighten securely in place. Note: machine may be operated with barrel partially filled
Note: If cookies do not cut off properly even though dough consistency is correct, make sure the 3 feet of the barrel cap touch the cookie sheet each time in order to form the cookie. As the gun is lifted, the flow of dough is cut, forming the cookie on the sheet.
Nov 23, 2012 | WearEver Wear-Ever Super Shooter Electric...
Fan is still on water pump in car how do you remove fan from 1993 ed ford
the fan is bolted onto a spacer that connects to the water pump-the bolts on the front of the center of the fan need to be removed, and in a lot of cases you need to remove the top cover and/or the fan surround to gain enough access to them. Don't remove the belt from the fan since you will need then to hold the assembly while you loosen the bolts.
Aug 05, 2011 | Ford Fairmont Cars & Trucks
Need location and r/r proceedure for fan blower motor on a 2001 grand cherokee limited.
backside of radiator you will see the fan shroud and fan assembly.
4 - 10mm bolts (one on each corner) will be holding it in place.
Remove the bolts (this will take some time as these bolts are in very tight areas) once the bolts are removed, very carefully pull the trans cooler line out of its mounting on the fan shroud (bottom drivers side of the shroud)
Pull fan and shroud out thru the top (be very careful wiggling it out, you do not want to break the shroud)
Once out, remove the fan motor (4 bolts and a round clip holding it in place)
Replace in reverse order.
Hope this helps
Jul 11, 2011 | Jeep Grand Cherokee Cars & Trucks
How do I replace the heating fan on my 2000 Kia sportage
Blower Motor
Removal & Installation
To Remove:
  1. Evacuate and recover air conditioning refrigerant.
  2. Remove battery.
  3. Disconnect and cap A/C lines at evaporator tubes.
  4. Remove blower motor assembly drain.
  5. Remove glove box.
  6. Remove 5 screws and right hand instrument panel lower trim panel.
  7. Remove screw that attaches upper center console to gain access to left
    instrument panel lower support.
  8. Remove left and right bolt and remove instrument panel lower support.
  9. Detach control cable from inlet duct.
  10. Disconnect blower motor electrical connector.
  11. Pull carpet back and remove hole cover plate.
  12. Remove 2 bolts at top of blower motor assembly.
  13. Remove 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  14. Remove blower motor assembly.
To Install:
  1. Install blower motor assembly.
  2. Install 2 bolts at top of blower motor assembly.
  3. Install 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  4. Install hole cover plate and replace carpet.
  5. Connect blower motor electrical connector.
  6. Install instrument panel lower support and install left and right bolts.
  7. Install right hand instrument panel lower trim panel and 5 screws.
  8. Install glove box.
  9. Install blower motor assembly drain hose.
  10. Connect evaporator lines at bulkhead.
  11. Evacuate and charge air conditioning refrigerant.
  12. Install battery.
Oct 29, 2010 | 2000 Kia Sportage
How to change a radiator
1988–91 Models
  1. Disconnect the negative battery cable.
  2. Properly drain the cooling system into a suitable container.
  3. Disconnect the fan motor and motor connector.
  4. Disconnect the upper and lower radiator hoses.
  5. Disconnect and plug the automatic transaxle cooling lines at the radiator, if equipped.
  6. Disconnect the coolant reservoir overflow hose.
  7. Remove the radiator attaching bolts and brackets.
  8. Remove the radiator with the cooling fan attached.
  9. Remove the cooling fan and shroud from the radiator. NOTE: Check all cooling system hoses for any signs of damage, leaks or deterioration and replace if necessary. To install:
  10. Attach the cooling fan and shroud to the radiator and install the assembly.
  11. Attach the radiator bolts and brackets. Tighten the radiator bracket bolts to 7 ft. lbs. (10 Nm).
  12. Connect the coolant reservoir overflow hose.
  13. Connect the automatic transaxle cooling lines to the radiator, if equipped.
  14. Connect the upper and lower radiator hoses.
  15. Connect the fan motor and thermo-switch wire connector.
  16. Refill the system with the proper type and quantity of coolant, check for leaks and bleed the cooling system.
  17. Reconnect the negative battery cable. Fig. 7: Cooling system components — 1988–91 engines 86833085.gif
1992–95 Models
  17. Reconnect the negative battery cable. Fig. 8: Cooling system components — 1992–95 engines 86833086.gif
Aug 27, 2010 | 1991 Honda Civic
37 people viewed this question
jasbo
jasbo
